My Cart Work Offline But Not Online
Thread begun 2/10/2020 1:34 am by nicesobhi2975262593 | Last modified 2/18/2020 7:06 pm by Ray Borduin | 2065 views | 5 replies |
nicesobhi2975262593
Dear All,
i'm trying to develop Web Application dealing with warehouse ,
so i developed cart to do this , it is working offline but when i upload it online not working
when i enter the page of cart and try to update price or click checkout , update in cart , the cart turns into empty cart !!!
so please help me
It could be an issue with session configuration on your live site. Try creating two pages. The first one with:
@session_start();
$_SESSION["test"] = "working";
The second page put:
@session_start();
var_dump($_SESSION["test"]);
Then browse the first page followed by the second. See if the session variable value displays "working". If not, then the server is mis-configured. Most likely the session_save_path is pointing to a non-existent directory or a directory without write permissions.
nicesobhi2975262593
thanks for fast reply
so how can we configure the server (mis-configured)
if the problem as you say
Contact your hosting provider. Show them the problem and they should be able to fix it for you. It is most likely a bad directory in the php.ini settings file for the session_save_path.
nicesobhi2975262593
i'm using classic asp not php
Are you moving from a www.domain version to one without www. or vice versa? That would cause the cart to be cleared.
