Confirmation email not received
Thread begun 2/06/2020 1:29 pm by john70964 | Last modified 3/16/2020 2:31 pm by Ray Borduin | 5862 views | 39 replies |
john70964
Confirmation email not containing information
Hi Ray
I have some files that allow insert of items and an image, enter these in a database and then send an email to the sender and myself confirming details.
The procedure is carried out OK with the exception that the email that arrives does not contain any of the items entered.
I wondered if you can see why this should be.
I have attached the files
Many thanks
John
It doesn't look like your email server behavior has any attachments added. Update the email server behavior on the
boat_insert_images_Free.php page and use the attachments button to add the attachment from your file upload field to include it in the email.
john70964
Thank you Ray for the explanation,
I think I have opened the correct document but I am not sure of which selection to make from the select Data Bindings.
Thanks for the help.
John
Use the submitted file radio button to add the submitted file as an attachment to the email.
john70964
Hi Ray
I think I followed your instructions, but no detail appeared on thankyou.php when it arrived here from the website.
I am attaching the files and a picture.
John
It looks like you didn't use the "Submitted File" radio... The attachment settings should look like the file I have attached.
john70964
Hi Ray,
When I run the insert pages the information goes into the database correctly and the image appears correctly in the updating permissions page, so the details have been recorded correctly.
Notification of the details should come to me in order I know an advert has been placed.
Until recently the email appeared but was empty of any detail.
After my amendments the email does not arrive at all. I just cannot see why this has happened. Obviously something I have changed.
I wonder if you can spot where I have gone wrong?
I am attaching the latest files hoping you can spot the problem.
One strange occurrence, when I look at the files in ftp
webassist/mysqli/
On the localhost directory I have two files
queryobj.php Last modified 25 12 2018
rsobj.php Last modified 25 12 2018
On the remote directory I have
authentication.php Last modified 05/02/2020
queryobj.php Last modified 05/02/2020
rsobj.php Last modified 05/02/2020
So the remote is showing a later update than the localhost.
That seems unlikely?
Many thanks
John
You have a redirect specified for your UPDATE server behavior that is causing the redirect to happen before the email can get sent. Remove the redirect from the MySQLi Update Record server behavior and add it to the Send Email server behavior instead so that the email has time to send.
john70964
Thanks Ray
I carried out the changes, uploaded via FTP but received this error.
Fatal error: require(): Failed opening required 'Block_6.php' (include_path='.:/usr/lib/php5.6') in /homepages/37/d415519235/htdocs/boatsforsalenow/webassist/email/WA_Email.php on line 314
Please see attached files.
I wondered if the trigger should be changed to current page submit, I seem to remember that cropping up previously.
I also wondered in the SB Send Email if the text in the email body Block Template needs changing.
You have to upload the page:
/webassist/email/templates/WebAssist-Block/Block_6.php
