instal error
Thread begun 2/06/2020 7:12 am by Jonas | Last modified 2/08/2020 2:14 am by Ray Borduin | 621 views | 1 replies |
Jonas
instal error
Does PowerCMS still work? I have tried installing both locally and on remote server, but get error message.
Local: The database tables are created but at the end of the installation, the "http://localhost:8888/aboutBeerNyServer/install_cms/database.php" page appears blank. And when I try to show: "http://localhost:8888/aboutBeerNyServer/admin_cms", it will restart the installation.
Remote: No table is created and it gives error message:
Fatal error: Uncaught Error: Call to undefined function mysql_select_db() in /www/webvol16/z3/e7v7i55mki9ry4i/jonasn.se/public_html/aboutbeer/install_cms/global.php:13 Stack trace: #0 /www/webvol16/z3/e7v7i55mki9ry4i/jonasn.se/public_html/aboutbeer/install_cms/index.php(2): require_once() #1 {main} thrown in /www/webvol16/z3/e7v7i55mki9ry4i/jonasn.se/public_html/aboutbeer/install_cms/global.php on line 13
PowerCMS has not been updated for php7 support yet. The errors you are getting are because your server is php7.
I have an early ALPHA of a version that should work on php7 here:
https://www.webassist.com/PowerCMS.zip
There is a lot of work still that I need to do to update other tools in Design Extender and add new features, but this may be a good stop gap.
