NOT A QUESTION BUT A SUGGESTION ON ROW NUMBERING IN A REPEATING LIST
Thread begun 2/05/2020 12:00 pm by Web Manager | Last modified 2/08/2020 2:10 am by Ray Borduin | 363 views | 0 replies |
Web Manager
What you need to do to add row number to your repeating list is to add this
<?php $rowcount = $rssba_login->StartRow; ?>
prior to the repeating code below change the $rssba_login to your recordset name
$wa_startindex = 0;
while(!$rssba_login->atEnd()) {
$wa_startindex = $rssba_login->Index;
Then create a blank column 1st in your repeating table row line and add this <?php echo ++$rowcount -1; ?>
This will give you the correct number row number when paging through your list
