Multiple image upload
Thread begun 1/30/2020 10:03 pm by danielsebas | Last modified 2/19/2020 7:34 am by Ray Borduin | 808 views | 2 replies |
danielsebas
Hi Ray, with DataBridge 2, is it possible to upload multiple images and insert their info into a database?
Not without a bit of hand coding. The file upload will work with multiple files, but you would have to create your own loop to do multiple inserts based on the multiple uploads if you might be renaming existing files. If file names don't change and existing files are overwritten, then it could be done with the multiple insert server behavior. I'd really have to understand the application specifics of your requirements to know if hand coding was necessary or not. It will certainly get you 90% of the way there if not 100%.
Sweens
This would be a really useful addition. Please can we have it built in????
I have a great multiple file upload extension but having upgraded to php7.3, it no longer works - and the extension developer seem to have gone out of business!
Cheers
Chris S
