Problem with multiple insert server behavior
Thread begun 1/30/2020 11:22 am by illbe322016 | Last modified 2/02/2020 8:11 pm by Ray Borduin | 994 views | 2 replies |
illbe322016
I have been following the tutorial http://www.webassist.com/community/tutorials/view_tutorial.php?tid=25&accesscheck=/community/tutorials/view_tutorial.php?tid%3D25 and have an issue with my insert page, everything is fine up to the point of adding the insert multiple records server behavior, I keep getting this error:
Parse error: syntax error, unexpected '' (T_ENCAPSED_AND_WHITESPACE), expecting '-' or identifier (T_STRING) or variable (T_VARIABLE) or number (T_NUM_STRING) in /homepages/30/d351966251/htdocs/lynchdesign/advertisers_insert.php on line 16. Line 16 is the session variable apparently. I have included my code below. As usual, thank you for your help, I, sure it may be something I missed but I have gone back and forth several times and am out of ideas.
Line 16 has:
$InsertQuery->bindColumn("advertiserID", "i", ".$_SESSION['WADA_Insert_advertisers'] .", "WA_BLANK");
it should be:
$InsertQuery->bindColumn("advertiserID", "i", "".$_SESSION['WADA_Insert_advertisers'] ."", "WA_BLANK");
Make sure you have downloaded and installed the latest version (reinstall the extension). I think this may have been an issue in a previous version that has been corrected.
illbe322016
Thank you Ray, that fixed the issue. I did re-download the extension and re-install (v2.3.5) but when I inserted the behavior again I got the same result with the extra quotes, just a heads up. Thank you again for the quick reply and fix. - Tom
