empty field was null in mysql db now 0 in MariaDB with mysql_i
Thread begun 1/29/2020 7:23 am by Sweens | Last modified 1/30/2020 7:20 pm by Ray Borduin | 1055 views | 2 replies |
Sweens
Hi
I have a form which hades certain fields, depending on set values. For example:
<?php if ($_GET['pt'] <>"5" OR $_GET['under']=="mp"){ ?>
<input name="UnderPage" type="hidden" id="UnderPage" value="" />
<?php } ?>
When on a mysql database, using mysql server behaviours, the above code returned a NULL value - bit now we've changed to MariaDB and mysql_i, a 0 is inserted instead of NULL.
The appropriate line from the update behaviour is
$InsertQuery->bindColumn("Under_PgID", "i", "".((isset($_POST["UnderPage"]))?$_POST["UnderPage"]:"") ."", "WA_NULL");
which should set a NULL value - but presumably because the value is now 0, it is ignored.
Is there a way round this, so I don't have to update all the non-admin pages that look for NULL values in this field.
Many thanks
Chris
It looks like it should do a Null value... can you provide FTP access and a url that I can use to test with? I'll look into it and see what might be causing this problem.
Sweens
Hi Ray
Thanks - it turns out that its only 2 pages that are affected, so I've just altered the query on those pages to accept 0 or NULL values.
Cheers
Chris
