Show/hide region if rows contain/don't contain
Thread begun 1/26/2020 1:52 am by Sweens | Last modified 1/30/2020 7:17 pm by Ray Borduin | 1543 views | 5 replies |
Sweens
I have a recordset that returns 2 page types (PgTypeID is the field name).
I have 2 repeat regions on the page, based on the value of the PgTypeID.
The recordset may have 10 records with PgTypeID = 5, but none with PgTypeID=2.
There is a 'show if recordset is empty' behaviour, which obviously works if no records are returned - but how can I do it so that 'if there are no rows where PgTypeID = 2' show 'No pages of this type' ?
What I have so far (simplified):
$wa_startindex = 0;
while(!$rsPages->atEnd()) {
$wa_startindex = $rsPages->Index;
<?php if ($rsPages->getColumnVal("PgTypeID") <> "2") { ?>
<p>display contents</p>
<?php } ?>
$rsPages->moveNext();
$rsPages->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
Many thanks
Chris
Maybe add a separate recordset to return the number of rows with each page type. Then you could use those recordsets to create the Show If message.
Sweens
Thanks Ray - I'll try that.
Cheers
Chris
Sweens
Actually, the easiest way would be to separate the recordset into 2, then just use the standard 'if recordset empty' behaviour. (which is what I originally had. I combined them trying to get fewer calls to the database on the page, assuming this would be quicker).
Cheers
Chris
You could use a single recordset if you wanted to create a more complex SQL statement like:
SELET COUNT(IF(PgTypeID= 5, 1, NULL)) AS Type5Count, COUNT(IF(PgTypeID= 2, 1, NULL)) AS Type2Count, * FROM...
But I'm not sure if it would be any more efficient than separate recordsets, so I still think adding recordsets to get the counts would be easier. If it did save any time it would be milliseconds and probably not worth the extra effort.
Sweens
Thanks Ray. I'll take your advice and go with separate recordsets.
Cheers
Chris
