Insert error
Thread begun 1/23/2020 4:28 am by María Luisa | Last modified 1/23/2020 10:20 am by Ray Borduin | 2452 views | 6 replies |
María Luisa
Insert error
Hi
I have a simple form: two radio buttons, a text field and a text area.
The idea is that when the user clicks the radio button id moda1, the read-only text field modalidadE (id fijo) becomes available for the insert.
If, on the other hand, you click on the radio button id moda2, the previous field is disabled and the user can enter the text in the text area (id tcontenidoMod).
The corresponding column in the database is always the same: modalidad2. The name of the text field and the text area is ModalidadE.
Here my code.
<?php require_once('../webassist/mysqli/queryobj.php'); ?>
<?php require_once('../Connections/conexion.php'); ?>
error_reporting(E_ALL);
ini_set('display_errors', '1');
<!doctype html>
<html>
<head>
<meta charset="UTF-8">
<title>PRUPRU</title>
<script src="https://cdnjs.cloudflare.com/ajax/libs/jquery/3.3.1/jquery.min.js"></script>
if(isset($_POST['modalidadE'])){
$modalidadE= $_POST['modalidadE'];} ?>
if (isset($_POST["enviar"]) || isset($_POST["enviar_x"])) {
$InsertQuery = new WA_MySQLi_Query($conexion);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "modensayo2";
$InsertQuery->bindColumn("modalidad2", "s", "".($modalidadE) ."", "WA_DEFAULT");
$InsertQuery->saveInSession("insertado");
$InsertQuery->execute();
$InsertGoTo = "";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
</head>
<body>
<form action="" method="post" name="formulario" id="formulario">
<table>
<tr>
<td>
<input type="radio" name="radioMod" id="moda1" value="0" checked>
</td>
<td><input name="modalidadE" type="text" class="form-control" id="fijo" value="Este texto será siempre el mismo" size="60" readonly="readonly">
</td>
</tr>
<tr>
<td>
<input type="radio" name="radioMod" id="moda2" value="1">
</td>
<td><textarea name="modalidadE" cols="60" rows="3" class="form-control" id="tcontenidoMod" placeholder="Escriba aquí su texto para Modalidad de Ensayo"></textarea>
</td>
</tr>
<tr>
<td></td>
<td>
<input name="enviar" type="submit" value="Enviar">
</td>
</tr>
</table>
</form>
<script>
$(document).ready(function(){
$("input[name='radioMod']").change(function(){
if($(this).val()==1){
$("#fijo").attr("disabled",true);
$("#tcontenidoMod").removeAttr("disabled");
} else{
$("#tcontenidoMod").attr("disabled",true);
$("#fijo").removeAttr("disabled");
</script>
</body>
</html>
If I insert with the radio button id moda2, the text inserted in the text area is written to the database correctly. But if I click on the first radio button to insert the default text of the text field into the database first, it gives me a series of errors that I copy below.
( ! ) Warning: Wrong parameter count for mysqli_stmt::bind_param() in /Applications/MAMP/htdocs/CST_Fluidos_01/webassist/mysqli/queryobj.php on line 466
Call Stack
# Time Memory Function Location
1 0.0015 365720 {main}( ) .../Prueba_input2.php:0
2 0.0189 530296 WA_MySQLi_Query->execute( ) .../Prueba_input2.php:25
3 0.0192 530704 bind_param ( ) .../queryobj.php:466
There is an error in your SQL syntax.
The line 25 in my code is: $InsertQuery->execute();
I do not know what I'm doing wrong. Can someone help me please?
Have you re-installed recently to get the latest version of queryobj.php? I'm thinking there may be an issue in your version causing the problem. I've attached the latest version, please try replacing it and see if that corrects the problem. If it does, then try reinstalling either Data Bridge or MySQLi Server Behaviors to make sure the latest version is used in future applications.
María Luisa
The problem continues
Thanks Ray, as always, for your kindness.
I have replaced the queryobj.php that indicates the one I had installed. But the problem continues when I try to insert from the first radio button: I click on it and when I click the submit button, this error appears:
( ! ) Warning: Wrong parameter count for mysqli_stmt::bind_param() in /Applications/MAMP/htdocs/CST_Fluidos_01/webassist/mysqli/queryobj.php on line 494
Call Stack
1 0.0014 365720 {main}( ) .../Prueba_input2.php:0
2 0.0093 541544 WA_MySQLi_Query->execute( ) .../Prueba_input2.php:25
3 0.0097 541952 bind_param ( ) .../queryobj.php:494
In the case of queryobj.php that previously indicated on line 466 now reference it in 494.
I do not know what I did wrong
You have:
Most likely that column doesn't have a default value, so you would need something like:
$InsertQuery->bindColumn("modalidad2", "s", "".($modalidadE) ."", "WA_BLANK");
The other issue is that you must not be getting a value set for $modalidadE. This happens because you have the attribute: readonly="readonly"
When a field is set to readonly it isn't actually submitted with the form. To fix that you could probably use:
$modalidadE
"Este texto será siempre el mismo";
if(isset(
$modalidadE$_POST['modalidadE'];} ?>
instead of what you have now:
María Luisa
Some things are solved
Thanks a lot again Ray.
With these changes that you proposed to me the error no longer occurs when I insert the text corresponding to the first radio button but, nevertheless, nothing is inserted in the database in the corresponding column although something happens in the insertion because it generates an id in the corresponding column of that table.
It occurred to me to remove the readonly attribute from the text field, but the same thing happens: do not write anything in the table when inserting.
In the case of the second button, it continues to work perfectly
I think I see why. Try using:
$modalidadE
if(isset(
$_POST['modalidadE']) && $_POSt["radioMod"] !== "0"){
insead of:
$modalidadE
if(isset(
María Luisa
Solved!! :)
Ohhh, Ray, thanks a million. How fine, it was necessary to add the condition that the value of the radio button was 0.
It is perfectly solved.
