Adding German shipping for European countries, even though shipping is set to 0.00
Thread begun 1/20/2020 10:25 am by Roxana | Last modified 1/20/2020 3:34 pm by Ray Borduin | 2834 views | 9 replies |
Roxana
Since updating to MSQLi, the cart description does not recognize customers from Europe.
Europe is set to 0.00 for shipping rate, but the cart will add German shipping rate and include it in the tax calculation and total for customer from Europe. Apparently it does not recognize customers as being from the European Union. Before the upgrade to MSQLi this wasn't a problem.
It looks like german shipping is added when there is a value set for $_SESSION['germanShipping'] and $_SESSION['mylocation'] is set to "not canada".
So my guess is that the issue is on the page where $_SESSION['germanShipping'] is being set and that you have to make sure that value is properly cleared or at least not set when someone is from another area.
Roxana
This is the code on the confirm page:
<?php if(isset($_SESSION['germanShipping']) && $_SESSION['germanShipping'] != ""){
$_SESSION['germanShipping'] == $_SESSION['euroShipping'];
There has to be other code. The code you sent would set the german shipping value to the euro shipping amount if there is a value for german shipping set already. There has to be other code that sets the german shipping to begin with.
Roxana
This is on the cart page:
$_SESSION['germanShipping'] = on;
How can you detect if someone is actually from Germany and you want German shipping applied?
It looks like it is automatically set to on and then automatically set to the european amount. I can't see how you could tell if someone is actually from Germany. Is there another session value you could use?
Roxana
When the customer enters their shipping address on the checkout page, they are redirected to confirm_germany, confirm_europe, confirm_international or confirm_canada depending on the shipping entry.
international has no shipping (so that works), and Canada has a higher amount for shipping (that works too). Just European shipping does not work.
Roxana
I think I got it wrong. It is not the user entry, it is their location. With this code:
//Redirect to confirm.php if shipping_country is Germany
if($rseurope->getColumnVal('is_European') == 2){
header("Location: confirm_germany.php");
elseif($rseurope->getColumnVal('is_European') == 1){
header("Location: confirm_europe.php");
elseif($rseurope->getColumnVal('is_European') == 3){
header("Location: confirm_canada.php");
On segufix_PHP.php line 117 you have:
if (true && ((isset($_SESSION['germanShipping']) && ((isset($_SESSION['mylocation'])?$_SESSION['mylocation']:"") == "not_canada")))) {
I think this might work:
if (true && ($_SESSION['languageID'] == 1)) {
maybe this:
if (true && ($_SESSION["eCartCheckoutForm_shipping_country"] == "DE")) {
Roxana
OK, I got it to work. The language setting is not used to determine location (e. g. Austria is European Union, but German is the language), and shipping entries are one of four languages.
Instead building on what you mentioned before, I unset the germanShipping session and enabled euroShipping. It works now. What baffles me is, that it has worked for many years without the change.
unset($_SESSION['germanShipping']);
$_SESSION['euroShipping'] = on;
Thank you :)
