I want to show the month name at the beginning of each month, along with the products
Thread begun 1/14/2020 9:19 am by Jonas | Last modified 1/16/2020 9:10 am by Ray Borduin | 2737 views | 10 replies |
Jonas
I have a result page from a product database, where I want to list the products in date order. I also want to show the month name at the beginning of each month. The table contains the following columns: ProductID, ProductMonth, ProductDate, ProductName. How do I write this query?
I don't really understand the question. I think the query would just be:
SELECT * FROM products ORDER BY ProductDate
Then just write the month name at the beginning of each month like:
$lastMonth
while (!$recordset->atEnd()) {
if ($lastMonth != $recordset->getColumnVal("ProductMonth")) {
<h2><?php echo($recordset->getColumnVal("ProductMonth")); ?></h2>
  $lastMonth
= $recordset->getColumnVal("ProductMonth");
<!-- rest of your looped code here -->
Jonas
I think you understood! But I don't make it work. The page is empty (http error).
Attaches image to code and how it should look like (static code).
Delete line 115 it is a repeat of line 109.
Then move line 114 up above line 107
Jonas
Thanks, now it's getting closer!
The name of the month is now displayed only for the first product within the same month.
But at the same time, it seems that this table row, with the month name - appears under all products - which is obviously not good.
The attached screen shows these lines that I marked with red color (in css).
How do I make this row appear only with the month name?
You have:
<?php if ($RSProvningar->getColumnVal("ProvningManad") !="") { ?><tr class="manadsnamn">
                  <td colspan="4" >
<?php if ($lastMonth != $RSProvningar->getColumnVal("ProvningManad")) { ?>
<h2><?php echo($RSProvningar->getColumnVal("ProvningManad")); ?></h2>
<?php $lastMonth = $RSProvningar->getColumnVal("ProvningManad"); } ?>
                  </td>
                </tr> <?php } ?>
You probably just want:
if ($lastMonth != $RSProvningar->getColumnVal("ProvningManad") && $RSProvningar->getColumnVal("ProvningManad") !="") {
  <td colspan="4" >
  </td>
</tr>
$lastMonth
Jonas
You're right, as always. I learn new things all the time, thank you! One last question about this. Is it possible to make a separate table per month? See attached screenshot. Where the first line is the name of the month. The next line is the table head and then all the products for that month.
Please attach a current copy of the page and I can help.
Jonas
I've done that, can't you see it?
Try using this for your table:
<?php $lastMonth = "";?>
$wa_startindex
= 0;
while(!
$RSProvningar->atEnd()) {
$wa_startindex = $RSProvningar->Index;
if ($lastMonth != $RSProvningar->getColumnVal("ProvningManad") && $RSProvningar->getColumnVal("ProvningManad") !="") { ?>
if (isset($tableShown)) {
echo(
"</tbody></table>");
$tableShown = true;
            <table class="table table-hover">
              <thead>
                <tr>
                  <th scope="col"><i class="far fa-calendar-alt"></i></th>
                  <th scope="col"><i class="fas fa-chair"></i></th>
                  <th scope="col"><i class="fas fa-wine-glass-alt"></i></th>
                  <th scope="col"><i class="fas fa-coins"></i></th>
                </tr>
              </thead>
              <tbody>
                    <td colspan="4">
                    </td>
                </tr>
                <?php $lastMonth = $RSProvningar->getColumnVal("ProvningManad");} ?>
                  <tr class="text-black-50">
                    <td><?php echo($RSProvningar->getColumnVal("Dayname")); ?> <?php echo($RSProvningar->getColumnVal("Day")); ?> <?php echo($RSProvningar->getColumnVal("Month")); ?></td>
                    <td><?php echo($RSProvningar->getColumnVal("ProvningPlatser")); ?> st</td>
                    <td><?php echo($RSProvningar->getColumnVal("Kategorier_KategoriNamn")); ?></td>
                    <td><?php echo($RSProvningar->getColumnVal("KategoriPrisklass")); ?></td>
                  </tr>
if (1==0) {
          </tbody>
        </table>
  $RSProvningar
->moveNext();
$RSProvningar->moveFirst(); //return RS to first record
unset($wa_startindex);
unset(
$wa_repeatcount);
echo(
