using MM_update
Thread begun 1/12/2020 10:16 pm by randyrie405335 | Last modified 1/13/2020 10:38 am by Ray Borduin | 1177 views | 1 replies |
randyrie405335
using MM_update
Wrong Code:
Is "MM_update" a default and is it outdated? It appears in one of my PHP forms, seemingly by default, and doesn't work: "<input type="hidden" name="MM_update" value="frmUpdate"/>" which codes: [[(isset($_POST["MM_update"])) && ($_POST["MM_update"] == "frmUpdate")]].
Correct Code:
After I use Webassist's Update Record Form and select the proper submit button: "Button: button pressed" which codes: [[if (isset($_POST["button"]) || isset($_POST["button_x"])) {...]] , the form works.
So what causes the 'wrong' code to be entered via WebAssist's DataBridge?
It appears either code would work. The MM_update hidden field is how the old Adobe Update server behavior used to work. When you update to MySQLi from MySQL it keeps using that value to mimic the way the adobe version worked, but you can delete that hidden form element and use the button press trigger instead if you have issues with it.
