Call to undefined function mysql_data_seek() in /WA_eCart/WA_eCart_Definition_PHP.php:1272
Thread begun 1/10/2020 8:18 am by Jedi | Last modified 1/10/2020 11:39 am by Ray Borduin | 2975 views | 4 replies |
Jedi
I am converting a shopping cart site over from mysql to mysqli using databride and ecart 6. I'm stuck at the fatal error statement : Call to undefined function mysql_data_seek() in /WA_eCart/WA_eCart_Definition_PHP.php:1272.
I also can't figure out how to convert lookup data to mysqli with databride.
Now that you have updated your recordset to MySQLi, you should be able to click on your add to cart server behavior and re-apply it and the code will be automatically updated to MySQLi as well.
Jedi
I did and you were right, it did add the code. the only problem is I got this message now: fatal error: Uncaught Error: Call to a member function select_db() on null in /homepages/24/d812057846/htdocs/xxxxx.com/espantoon_detail.php:37 Stack trace: #0 {main} thrown in /homepages/24/d812057846/htdocs/xxxx.com/espantoon_detail.php on line 37
It looks like you have two recordsets on this page that were similarly named to others and that caused an issue when updating the recordsets to MySQLi.
If you update the code on lines 28-56 to:
$paramOption_rsFinishlookup
"-1";
if (isset(
$_POST['eCart1_1_Finish_Add'])) {
$paramOption_rsFinishlookup $_POST['eCart1_1_Finish_Add'];
$paramItem_rsFinishlookup "-1";
if (isset(
$_POST['eCart1_1_ID_Add'])) {
$paramItem_rsFinishlookup $_POST['eCart1_1_ID_Add'];
mysql_select_db($database_OConne_i$OConne_i);
$query_rsFinishlookup sprintf("SELECT productoptions.OptionPriceIncrement, productoptions.ProductOptionID, options.OptionName, options.OptionGroupID, optiongroups.OptionGroupName FROM options INNER JOIN productoptions ON options.OptionID = productoptions.OptionID INNER JOIN optiongroups ON options.OptionGroupID = optiongroups.OptionGroupID WHERE optiongroups.OptionGroupID = '1' AND productoptions.ProductOptionID = %s AND productoptions.ProductID = %s"GetSQLValueString($paramOption_rsFinishlookup"int"),GetSQLValueString($paramItem_rsFinishlookup"int"));
$rsFinishlookup mysql_query($query_rsFinishlookup$OConne_i) or die(mysql_error());
$row_rsFinishlookup mysql_fetch_assoc($rsFinishlookup);
$totalRows_rsFinishlookup mysql_num_rows($rsFinishlookup);
$paramOption_rsStraplookup
"-1";
if (isset(
$_POST['eCart1_1_Strap_Add'])) {
$paramOption_rsStraplookup $_POST['eCart1_1_Strap_Add'];
$paramItem_rsStraplookup "-1";
if (isset(
$paramItem_rsStraplookup $_POST['eCart1_1_ID_Add'];
$query_rsStraplookup sprintf("SELECT productoptions.OptionPriceIncrement, productoptions.ProductOptionID, options.OptionName, options.OptionGroupID, optiongroups.OptionGroupName FROM options INNER JOIN productoptions ON options.OptionID = productoptions.OptionID INNER JOIN optiongroups ON options.OptionGroupID = optiongroups.OptionGroupID WHERE optiongroups.OptionGroupID = '2' AND productoptions.ProductOptionID = %s AND productoptions.ProductID = %s"GetSQLValueString($paramOption_rsStraplookup"int"),GetSQLValueString($paramItem_rsStraplookup"int"));
$rsStraplookup mysql_query($query_rsStraplookup$OConne_i) or die(mysql_error());
$row_rsStraplookup mysql_fetch_assoc($rsStraplookup);
$totalRows_rsStraplookup mysql_num_rows($rsStraplookup);
Then they should show up in the Server Behaviors window so you can update them to MySQLi.
Jedi
Thanks Ray. That worked. I then fixed the confirm and ppconfirm pages and now the shopping cart works as intended.
You Rock!
