Reload CAPCHA
Thread begun 9/17/2009 12:45 pm by Brad Lawryk | Last modified 9/17/2009 2:13 pm by Brad Lawryk | 2870 views | 3 replies |
Brad Lawryk
Reload CAPCHA
Is there a way to have the option to reload the Capcha Image? Sometimes its very hard to read the image.
No, the contact form solution pack does not have an option to reload the captcha image.
You can make it more readable by adjusting the captcha properties in the WA_Globals.php file. See the Captcha Settings section of the following PDF:
contact_form_sp_globals.pdf
Brad Lawryk
Thanks Jason,
It only explains how to change colors. Other than making the color of the noise the same as the background, is there another way to cut down on the amount of noise?
Brad Lawryk
I messed with the colors enough that its now acceptable and put a border around the image. It's all good now.
