Cannot install DataBridge 235
Thread begun 12/29/2019 12:52 pm by john70964 | Last modified 1/02/2020 9:10 am by Ray Borduin | 3707 views | 14 replies |
john70964
I tried to install DataBridge 235 but received an error message that it requires version 9 or greater.
I have cs6 which I believe is version 9.
Any ideas please?
John
Version 9 is CS3 or maybe CS4... but it should work on CS6. Did CS6 show up in the list of installed programs in your extension manager? Was it selected?
john70964
Thanks Ray
I can see adobe extension manager is open in the task bar but it will not open any further.
If I right click on the task bar icon the left image shows but goes no further.
I'd try reinstalling Extension Manager CS6. Open the extension manager first and then use it to browse to the extension and open it.
john70964
Hello Ray,
I removed the Adobe Extension Manager.
I restarted the PC
I downloaded a new extension manager and installed this.
Same result, it does not open.
Maybe try the DMXZone extension manager if the adobe version won't work for you:
https://www.dmxzone.com/go/22670/dmxzone-extension-manager-for-dreamweaver/
john70964
Thanks Ray
That appears to have worked. I have made a note for that extension manager in future.
I wish to update webassist/mysql/rsobj.php with DataBridge 235 and anything else that needs this. How can I go about this please?
If you just add or edit a recordset on any page it will update the rsobj.php file, then upload it.
john70964
The DMX Zone Extension Manager seems to have stopped working.
I logged on as administrator and I was able to update the Adobe Extension manager. I believe I am now using DataBridge235.
Looking in htdocs the file rsobj.php does not have the latest date when I save the changes to a recordset. So I wondered if the update worked?
I updated the rsobj.php on the remote server but still get the message
Connection to MySQL server successfully established.
Fatal error: Uncaught Error: Call to a member function query() on null in /homepages/37/d415519235/htdocs/net100test/webassist/mysqli/rsobj.php:197 Stack trace: #0 /homepages/37/d415519235/htdocs/net100test/index2.php(6): WA_MySQLi_RS->execute() #1 {main} thrown in /homepages/37/d415519235/htdocs/net100test/webassist/mysqli/rsobj.php on line 197
This implies that your recordset connection is incorrect. Did you create a new MySQLi connection?
