Field 'pic' doesn't have a default value - on image update query
Thread begun 12/23/2019 3:28 am by Ashok | Last modified 12/24/2019 10:13 am by Ray Borduin | 1092 views | 3 replies |
Ashok
Hello,
Although I have set the default value, I am still getting the error - Field 'pic' doesn't have a default value - if I do not select the pic in update query. The pic is there as it is displayed on the page.
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../assets/img/",
'FileName' => "[FileName]",
'DefaultFileName' => "" .$getdoctor->getColumnVal("pic"). "",
'ResizeType' => "0",
'ResizeWidth' => "120",
'ResizeHeight' => "120",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
Maybe the value: $getdoctor->getColumnVal("pic") is blank?
Is the getdoctor recordset above the code that sets the default value? Please attach the entire page so I can see it in context in order for me to potentially spot issues in the recordset or form.
Ashok
$getdoctor->getColumnVal("pic") is not blank as I can show the image on the same page.
File attached.
Your Update server behavior binding is set to the form field value. Instead it should be set to the "Server File Name" in the file upload bindings.
This:
$UpdateQuery->bindColumn("pic", "s", "".((isset($_FILES["pic"]))?$_FILES["pic"]["name"]:"")  ."", "WA_DEFAULT");
Should be:
$UpdateQuery->bindColumn("pic", "s", "".($WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["serverFileName"])  ."", "WA_DEFAULT");
