Problem with page break when printing email order confirmation
Thread begun 12/19/2019 3:41 pm by Roxana | Last modified 12/23/2019 11:30 am by Ray Borduin | 1113 views | 3 replies |
Roxana
When printing the email order confirmation, the page breaks in the middle of a line. Depending on the amount of info, the page break will vary, but should not be breaking up a line. Is there a way to solve this?
You should be able to use CSS to prevent page breaks inside of elements like:
p {
page-break-inside: avoid;
See: https://css-tricks.com/almanac/properties/p/page-break/
Roxana
Thanks Ray, that seemed pretty straight forward. It is not working though. I added the code directly to the waue page.
What program are you using to view and print the email? Is this Outlook? Outlook express? An online mail program? This is something that is handled by the email program you are using, so each may work differently. I would just google the problem and email program you are using to see if others have found a solution.
