Array and string offset access syntax with curly braces is deprecated
Thread begun 12/17/2019 10:47 am by mbunal | Last modified 8/21/2021 1:02 pm by Ray Borduin | 4654 views | 7 replies |
mbunal
when insert record , i have this:
Deprecated: Array and string offset access syntax with curly braces is deprecated in /site/webassist/mysqli/queryobj.php on line 414
Deprecated: Array and string offset access syntax with curly braces is deprecated in /site/webassist/mysqli/queryobj.php on line 460
what is problem? i know this is just deprecation messages. but databridge2 use this deprecated codes still?
They must have put out a recent update to php and included this deprecated functionality. I've updated the extension to fix this error. If you reinstall the latest version it will update your rsobj.php file and queryobj.php file to correct this warning.
Ascend7
I have updated but still getting some errors in authentication.php on line 205, line 207, line 356 and line 358.
Please post the exact error messages or a link where I can view them and a copy of the page referenced in the error.
Actually I was able to spot the issue by looking at the line numbers. Here is an updated version of that file that should resolve this issue. I'll get the extension updated to include this file as well.
Lucas
Same problem php 7.4.22 and 8.0.9
Hi Ray! I've the same problem... Is it already solved?
I'm using MySQLi Server Behaviors,
Current version: 1.0.8 appears on the downloads page.
Thanks!
Yes, if you reinstall the latest versions of the rsobj.php and queryobj.php files will be updated to fix this issue. You would have to re-apply a recordset or database insert or update server behavior to update the file in your site and then upload it to get the new files.
Lucas
Excellent! Thanks a lot!
