Email not sending ... trigger issue?
Thread begun 12/07/2019 7:08 am by sandy170299 | Last modified 12/10/2019 7:07 pm by Ray Borduin | 4663 views | 27 replies |
sandy170299
This process updates 2 separate records in the users table, inserts a transaction into the transactions table, grabs the last transaction entered into the transaction table, and emails the users involved with that transaction details. The problem is, the email is not sending.
Can you see why this is not working? Does it have something to do with the trigger, Successful update? How can I get this email to be sent the very last thing, after the update and insert scripts run? Ignore all of the testing echo code output, FYI. Code is attached.
Also, it's not redirecting, probably because the email isn't being sent???
Thank you.
It looks like the email is using a trigger from a security rule "Successful update"... I'd have to look at the helper_groups_rules.php file to see that that rule means to see if that is the issue. It is likely that either the conditions of the rule aren't being met, or the getRecipient recordset has no results, or there could be an issue in the email body.
sandy170299
Please see code below:
function WA_Auth_GetComparisonsForRule($ruleName){
$comparisons = array();
switch ($ruleName){
case "Bad return url from encryption email":
$comparisons[0] = array(TRUE, "".((isset($_GET['badURL']))?$_GET['badURL']:"") ."", 2, "");
break;
case "Email address not found":
$comparisons[0] = array(TRUE, "".((isset($_GET['notFound']))?$_GET['notFound']:"") ."", 2, "");
break;
case "Email server failure":
$comparisons[0] = array(TRUE, "".((isset($_GET['EmailFail']))?$_GET['EmailFail']:"") ."", 2, "");
break;
case "Emailed password":
$comparisons[0] = array(TRUE, "".((isset($_GET['emailedPassword']))?$_GET['emailedPassword']:"") ."", 2, "");
break;
case "Encrypted email return set":
$comparisons[0] = array(TRUE, "".((isset($_SESSION["WAENCRYPTEDRETURNUSED"]) && $_SESSION["WAENCRYPTEDRETURNUSED"])?"1":"") ."", 2, "");
break;
case "Encrypted email return success":
$comparisons[0] = array(TRUE, "".((isset($_SESSION["WAENCRYPTEDRETURNSUCCESS"]) && $_SESSION["WAENCRYPTEDRETURNSUCCESS"])?"1":"") ."", 2, "");
break;
case "Failed log in":
$comparisons[0] = array(TRUE, "".((isset($_GET['failedLogin']))?$_GET['failedLogin']:"") ."", 2, "");
break;
case "Log in success":
$comparisons[0] = array(TRUE, "".((isset($_GET['loggedIn']))?$_GET['loggedIn']:"") ."", 2, "");
break;
case "Logged in to adminuser":
$comparisons[0] = array(TRUE, "".((isset($_SESSION['SecurityAssist_userid']))?$_SESSION['SecurityAssist_userid']:"") ."", 2, "");
break;
case "Logged in to pcms2_users":
$comparisons[0] = array(TRUE, "".((isset($_SESSION['SecurityAssist_UserID']))?$_SESSION['SecurityAssist_UserID']:"") ."", 2, "");
break;
case "Logged in to users":
$comparisons[0] = array(TRUE, "".((isset($_SESSION['SecurityAssist_user_id']))?$_SESSION['SecurityAssist_user_id']:"") ."", 2, "");
break;
case "Successful forgot password update":
$comparisons[0] = array(TRUE, "".((isset($_GET['fpsuccess']))?$_GET['fpsuccess']:"") ."", 2, "");
break;
case "Successful update":
$comparisons[0] = array(TRUE, "".((isset($_GET['success']))?$_GET['success']:"") ."", 2, "");
break;
case "Validated form":
$comparisons[0] = array(TRUE, "".((isset($_GET['invalid']))?$_GET['invalid']:"") ."", 2, "");
break;
return $comparisons;
function WA_Auth_GetGroup($groupName){
$group = Array();
switch($groupName){
return $group;
sandy170299
I know it's inserting and I know it's updating because I can see the calculations changing on screen, on the transferaction.php page. Additions and subtractions. The only snag is it is NOT sending the email, which is where the redirect is. All 4 of the processes, 2 updates, 1 insert, and 1 email, are all now using the trigger "before page load." Maybe they shouldn't be? I will attach the page again in a zip file.
Use the same trigger as the insert or update. The "Successful update" rule checks for a success url parameter which is designed for the page after the redirect if you append that parameter to the url. It is used to show a success message on the next page after an update.
sandy170299
Not sure I'm clear on this. All of them have the "before page load" option for the trigger at this time. Are you saying that i should use the Successful Update trigger for the email piece? Sorry - I just want to be clear.
No. I'm saying that trigger is designed for a success page after an update not for the same page as the update. If you want to send an email after an update then it should be on the same page and use the same trigger as the update. They should probably both be using a button press trigger if you want it to update based on a form submit.
sandy170299
All four processes ARE on the same page. I tried to put them in order. Updating the 2 tables first, then the insert script, then the email, which gets the last_id from the inserted recordset. Here's how the process works. The form is submitted on one page. It goes to a 2nd page, where it shows you what you have listed on the first page and asks you to confirm it. The third page of the process is actually where the udpating, inserting, and email takes place.
Should I eliminate the confirmation page and put all of the scripts on the page after the form is submitted? Or should I have the scripts run on the same page AFTER the submit button has been pressed?
I hope this makes sense to you.
Thanks.
I'm not sure what you are doing, but usually I put all of the actions on the same page, using the same trigger, which is the form button press event, and then redirect in the last one to the success page which does nothing other than display a message. It is more of a matter of preference than anything, but I find that easier for organizational purposes.
sandy170299
I have moved all of the code to the ledger.php page, which is included in index.php. Now, it's not updating, inserting, or sending an email. FYI, I am receiving NO errors.
Yep ... I'm stumped! :/ Thank you!
