Getting White Screen When Using Universal Email.
Thread begun 12/03/2019 8:49 am by BillHobbs | Last modified 12/04/2019 9:13 am by Ray Borduin | 3088 views | 8 replies |
BillHobbs
I've created a contact form and I want to pass the content and some dynamic data to the email that gets sent. In the previous version there was a way to create the data with dynamic links from the contact page via a window where you just selected the data. I don't see that feature in the latest version. So I'm not sure how to do this now. Currently I just get a white screen when I try to submit the form.
Is there a tutorial some where on how you pass data from the form to the page being emailed. I've attached the form and the page to be emailed so you can tell me where I'm going wrong. Thanks in advance.
I did do an error check and this is the error:
Notice: Undefined variable: connSiteDB in /home/xllqtqsxkjyu/public_html/contact-email.php on line 7
Fatal error: Uncaught Error: Call to a member function query() on null in /home/xllqtqsxkjyu/public_html/webassist/mysqli/rsobj.php:213 Stack trace: #0 /home/xllqtqsxkjyu/public_html/contact-email.php(9): WA_MySQLi_RS->execute() #1 /home/xllqtqsxkjyu/public_html/webassist/email/WA_Email.php(314): require('/home/xllqtqsxk...') #2 /home/xllqtqsxkjyu/public_html/webassist/email/WA_Email.php(473): WA_Email->getFromPage('contact-email.p...') #3 /home/xllqtqsxkjyu/public_html/contact.php(27): WA_Email->send(0) #4 {main} thrown in /home/xllqtqsxkjyu/public_html/webassist/mysqli/rsobj.php on line 213
This appears to be an issue with your Connections/connSiteDB.php file. It doesn't seem to define a connection with the name $connSiteDB like it should. That causes the errors on the page.
BillHobbs
I can look at the page contact-email.php and I see the dynamic data. It just shows the error when I submit the contact form.
I'm really not sure how to echo the data from the contact form into the email being sent.
I see. You just have to add this to the top of your email body page:
global $connSiteDB;
That will make the connection available for use on that page.
BillHobbs
Okay that made the database work. Now how do I display the information that was in the contact form. Name, Email, Message, etc. on that page?
You can add the form bindings to that page from the Bindings panel and then reference them on the email body page that way.
BillHobbs
I'm not sure how to do that. On the page that is submitted the only bindings that show up are for the rsSiteInfo recordset data. I don't see any bindings for the email form data. If you can just show me how to echo one form field I can take it from there. Thanks.
I've uploaded the two files.
It tried <?php echo $_POST["contactName"]; ?> and that gives me the values. Is there another way I should be doing with Universal Email?
One other this I noticed is that the email being sent isn't including images that are dynamic, links or css style sheets that have a dynamic url. The dynamic code shows the right information, but the links, css or images are shown.
You can see the form at http://focusonmybusiness.com/contact.html
sharon386323
Click the plus button from the bindings panel and choose "Form data" and then browse to your form page. That will add the form to the bindings so you can add it to the email body more easily.
It is supposed to automatically update relative paths to full paths in your email body. It might be doing something wrong. If you give me FTP access and steps to reproduce then I can debug the image and css issue. It should work and I don't see any obvious issues in your code.
BillHobbs
Thank you Sharon. The form binding worked.
