server validation based on condition?
Thread begun 11/27/2019 7:41 am by SCar87011738 | Last modified 12/01/2019 1:53 pm by Ray Borduin | 1286 views | 3 replies |
SCar87011738
Hello all,
I have a form with a datepicker.
The datepicker should allow some interval depending of the time of the day.
Example:
if it's < 13:59 the datepicker should allow me to select the day starting from tomorrow.
If it's > 14.00 the datepicker should allow me do select only the day after tomorrow and later.
I just applied a condition to the datepicker code, but I need to add this contition to the server validation too.
Should I edit the webassist server validation code manually or is there a way to do this with the WA interface?
Here is the code I edited for the datepicker (it seems to work):
$.datepicker.setDefaults($.datepicker.regional['it']);
$('#data_ritiro_obi').datepicker({
beforeShowDay: disableWeekends,
dateFormat: 'dd/mm/yy',
showAnim: 'show',
$time = date("H");
if ($time < "14") { // WebAssist Show If
minDate: '+1',
} else {
minDate: '+2',
Thanks in advance for any suggestion.
tony
You should be able to use date validation to set the minimum date. I think you could do a min date like:
<?php echo(date("m/d/Y", (date("G")>=14)?time():strtotime("+1 day"))); ?>
SCar87011738
Thanks for the reply, Ray.
But I can't see the condition.
Ho can I handle this?
If time it's < 14 the min date is +1.
But if time it's > 14 the min date is +2.
TIA
Tony
Set the min date to:
<?php echo(date("m/d/Y", (date("G")>=14)?strtotime("+2 day"):strtotime("+1 day"))); ?>
