Custom Coded Coupon
Hi Ray... just following up on your premium support with our custom free shipping coupon code. Sharing the files in case you can spot the issue.
I see the issue.
This line is missing parenthasis:
$couponGood = (isset($_SESSION["couponcode"]) && $_SESSION["couponcode"] == $allowCoupon && date("n/j/Y") == "11/22/2019" && ($x_value === 'FEDEXGROUND') || ($x_value === 'GROUND_HOME_DELIVERY'));
should be:
$couponGood = (isset($_SESSION["couponcode"]) && $_SESSION["couponcode"] == $allowCoupon && date("n/j/Y") == "11/22/2019" && (($x_value === 'FEDEXGROUND') || ($x_value === 'GROUND_HOME_DELIVERY')));
I think it should be the same line on both pages.
So this part:
if($_SESSION["eCart_FedEx_Quote"] > 0){
if ($couponGood) {
$_SESSION["eCart_FedEx_Quote"] = 0;
That I tried switching to:
if ($couponGood) {
$_SESSION["eCart_FedEx_Quote"] == 0;
Should still be the single "=" because we're setting that to 0, correct?
Yes, that should be a single equal sign.
