How to separate dynamic text by comma in a loop to end in without comma ?
Thread begun 11/20/2019 2:54 pm by Jose | Last modified 7/06/2020 11:13 am by Ray Borduin | 1470 views | 3 replies |
Jose
Hi there, I'm trying to use comma (, ) or this ( | ) to separate dynamic text in a loop but always ends in comma. Here is an example what I'm referring to
$wa_startindex = 0;
while(!$Meta_RS->atEnd()) {
$wa_startindex = $Meta_RS->Index;
<li><a href="#"><?php echo($Meta_RS->getColumnVal("name")); ?>, </a></li>
$LocaleMeta_RS->moveNext();
$Meta_RS->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
RESULTS
name1, name2, name3, name4, etc
so my idea is to end it like this name1, name2, name3, name4 using WebAssist
You could do:
$wa_startindex
0;
while(!
$wa_startindex $Meta_RS->Index;
                              <li><?php echo($wa_startindex != 0?", ":""); ?><a href="#"><?php echo($Meta_RS->getColumnVal("name")); ?></a></li>
  $LocaleMeta_RS
->moveNext();
unset(
$wa_repeatcount);
Jose
Thank you so much . That work correctly but it should be place after href
then it works properly. Thanks Ray
Jonas
This post has been deleted.
