PowerCMS Template pages - non-existent pages default to show most recent ID
Thread begun 11/12/2019 1:40 am by Mags | Last modified 11/13/2019 8:55 am by Ray Borduin | 1509 views | 4 replies |
Mags
I have a PowerCMS template page set up to display surveys in a repeating list. The URL for a typical survey would be, for example:
www.mysite.com/survey-detail?ID=survey-title
However, if someone tries to access a non-existent survey (for example one that's been deleted from the site), instead of getting a page not found error it's defaulting to show the most recent survey instead. In fact, you can add any words you like after ?ID= and it will still show the most recent survey. I've never seen this before - how can I prevent it from happening?
You would have to add a recordset to the top of the page and check to see if there was a valid result and redirect. I could help with that if you send me your FTP information and a sample URL to test with.
Mags
Hi Ray, that would be great thanks - details in PM section.
You are already getting the content from a recordset, so you just have to look to see if there is a result and redirect if there isn't. I added this code below the recordset:
if (!$row_rsSurveys){
header("location: https://www.vetprofessionals.com/site/404");
  die();
Mags
Many thanks Ray, working perfectly now!
