The qestion has to do with Both Javvascript and PHP
Thread begun 10/29/2019 8:01 pm by lr_leal239405 | Last modified 1/20/2020 10:42 am by Ray Borduin | 2953 views | 10 replies |
lr_leal239405
This question has to do with Both Javascript and PHP
Where it says Original Product Info,,updating the Qty should upldate across its own row only:
See below link, put a number and you'll seee that only the second ruw gets updated with the right amount basedon the quantity.
The first won't do it. Check my code: The first row takes the number Qty from the second row and runs calculation. I need the first to calculae itself.
You call both functions calcTotal()... you would need to name the functions uniquely to use the looped function declaration like you do. It should be as easy as adding the incremented number to the function name and the onblur event where it is called.
lr_leal239405
Yup, that was it, Seems to be working now. Thanks for clearing it out for me. My brain gets fried trying to learn al this although it's getting there.
lr_leal239405
If you get some time to breathe, I have been struggling with this one, which I know I'm 90% there but can't get it to 100%. it may be similar to the one just fixed above. This has to do with Next and Previous arrow keys combining what is coming from the php recordset and JavaScript to move thru the pictures for each one. I have and indexg6.php which moves from box to box instead of each one within the box.(I also tried indexg7, g8, g9) but I think the indexg6.php is the one I'd go back to. indexg7.php has more code but it's displaying all picts in each box instead of one at a time.
I had to add a unique identifier for each product to all of your function and index references. I've fixed the page and uploaded it for you.
lr_leal239405
Ooh. I was hoping you'd ask and I was going to ask you if you could keep it to 1/2 hr. I had budgeted that much. I only needed one page on this last one.
Let me check it out and see if it works. Thanks.
Ok. I tried one and seemed to work. But my budget was 1/2 hr. Can you do 15min increments?
Thanks much again.
lr_leal239405
private
I cancelled the 1 hour invoice and sent you a 30 minute one instead. Please contact me via Skype for private conversations and to schedule paid support.
lr_leal239405
I've added that functionality to the page.
