My server is running PHP 7.1.32 and I have Dreamweaver CS5. I just bought the new mySQLI Server Behaviors, however I can not Connect to my mySQLI database using the built in Dynamic mySQLI Connection with in Dreamweaver. HELP
Thread begun 10/25/2019 12:10 pm by stanforrest151613 | Last modified 10/29/2019 11:44 am by Ray Borduin | 3407 views | 8 replies |
stanforrest151613
I get an error stating that I am trying to connect through a PHP mySQL and the MM_Server Scripts are set to another connection type. Please delete the _MMServer Scipts folder outside of Dreamweaver and try again.
stanforrest151613
Originally Said By: stanforrest151613
I guess I will have to ask for a refund if I cannot get any support for your product. Two other questions that came in way after my question have been answered by Ray Borduin. Looks like I am not getting any support.
I am the webassist support person.... So if I'm answering your questions you are getting support.
Anyway, if you continue to have issues you can post a US phone number or Skype contact information and I'll do screen sharing with you to help you identify what is wrong with your Dreamweaver site settings to help you connect to the database.
It is almost always a bad setting the testing server section of your Dreamweaver connection. If you do want a refund I can of course process that, but you might as well let me get it working for you first so you can properly evaluate it.
stanforrest151613
I posted my number to you in the private section of this post.
I do not want a refund, I simply want to be able to connect to my database so I can get started on a project.
FYI: I just upgraded to the most current version of Dreamweaver CC
Thank You
Stan Forrest
stanforrest151613
Okay I have finally got everything to connect and all is well. Took me a bit but everything seems to setup correctly.
Thank You
Stan Forrest
Post a new thread with new questions here and I will help you through your issues.
stanforrest151613
HTTP 500 error
Getting the following error with DataBridge V2 on all [pages generated by security assist
HTTP 500 error
That’s odd... the website can’t display this page
stanforrest151613
Call to undefined function virtual()
I placed the copy of the error from the error logs in a private message to you ray
In your site definition in Dreamweaver, go to Advanced Settings-> Local Info. Change Links relative to: from Site Root to Document.
That will make Dreamweaver use require_once() instead of virtual() for all of the includes. You may have to manually update the ones already created to fix this issue. You need to use document relative includes on your server.
