Search?
Thread begun 10/22/2019 10:09 am by Steve | Last modified 10/23/2019 2:31 pm by Ray Borduin | 4335 views | 24 replies |
Steve
Search?
Does the Search Feature still work?
There is a search in MySQLi but it only generates the code to determine what is being compared. I don't see any binding to a recordset to process the results.
Also, the Help file for that behavior is looking for "dataassist_select_recordset.html" which is not local on my computers. And this help file does not clearly explain the parsing to a filtering recordset:
http://www.webassist.com/tutorials/Create-a-search-page-that-displays-filtered-results
To clarify the MySQLi Search generates the following only:
$searchrs_Search1_1 = new WA_MySQLi_Search("rs_Search1","0=0");
if ($_SERVER["REQUEST_METHOD"] === "POST") {
$searchrs_Search1_1->clearSearch();
$searchrs_Search1_1->setSearch(array("type"=>"Value", "comparison"=>">", "join"=>"AND"), array("list_price"), "d", "".((isset($_POST["pricefrom"]))?$_POST["pricefrom"]:"") ."");
$searchrs_Search1_1->setSearch(array("type"=>"Value", "comparison"=>"<", "join"=>"AND"), array("list_price"), "d", "".((isset($_POST["priceto"]))?$_POST["priceto"]:"") ."");
Steve
Update:
I found another search titled Search Wizard which looks to step through the process a bit further. BUT on the final page as shown attached the "Finish" button does nothing. No click recognized both from the mouse/cursor and the Enter key. The Help button works but not the Finish button.
I was able to reproduce this issue with the screenshot you gave. I've done an update the the extension to fix the problem. If you reinstall DataBridge, the finish button should work properly.
The search feature works. It should have you specify the recordset in the UI. In this case the recordset you are using is: "rs_Search1"
In the code it is the first argument of the object:
Steve
Hello,
I encountered a number of different issues. I've installed the latest DataAssist and will try again.
Check out the screenshots that show the selection of a Column but that choice being replaced with some integer (246 in this case).
Another error is that the search conditional drops the comparison causing the page to have a fatal error.
after updating to add the new search column:
if (isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"]) {
Should be:
if ((isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
Can I see a copy of your page. I think it might have something to do with the results page you are applying the search to.
Steve
I've provided the current page which is in development but was the one showing the prior noted issues. I'm working out the optional fields using the MySQL method as that one did work prior. Once I get it working properly, I'll be moving that to the MySQLi version which is the end goal.
I don't see an issue with the page that would cause this. Can I get FTP access to test with your database and see if I can reproduce the issue that way?
Steve
Details attached
I've updated the page to MySQLi for you.
I was able to reproduce the column issue and get it fixed in the live build that I'm uploading now. If you reinstall, that issue will be resolved as well.
