HOW CAN I ACCESS FILES
Thread begun 10/21/2019 3:48 am by software.current355386 | Last modified 10/21/2019 9:20 am by Ray Borduin | 671 views | 1 replies |
I HAVE A DOMAIN POINTING TO A DOMAIN DIR ON MY PRIMARY DIR ON MY HOSTING SITE, 1 FOR EACH DOMAIN
PRIMARY DIR/ DOMAIN DIR
WHAT I WOULD LIKE TO DO IS CALL UP THE FILES ON THE PRIMARY DIR FROM THE DOMAIN DIR CAN THAT BE DONE IF SO HOW
Sometimes that is possible. It depends on the security settings and permissions on the server. What type of files are you trying to call up and use? Sometimes you can use relative paths that go above the site root and then up into the other site directory in order to reference a file in the code. You could also try using an absolute path. I think you can get the absolute path of a php page with:
<?php realpath(""); ?>
