My sorting is not working and I may have some vulnerable GET code that should be updated.
Thread begun 10/17/2019 1:14 pm by jo271221 | Last modified 10/18/2019 10:24 am by Ray Borduin | 667 views | 2 replies |
jo271221
I am attempting to sort desc by Year, Month Day, all the posts are in order except one and I checked the database and everything looks fine.
I have attached details including a screen shot of the DB columns in an effort to save you time.
Thank you,
The $_GET references are ok. They are always referenced with GetSQLValueString... that has SQL injection protection built in.
The issue with the sorting is due to the data type you are using. Since you are using varchar fields, the order is different than numeric ordering.
That column has a month set to "10"... well using a varchar sort, "10" comes before "2". I updated your SQL to convert the text value to an integer before sorting and that has fixed your issue.
jo271221
Thank you! That was going above and beyond. I appreciate it.
