sql error results page not displaying data all the time
Thread begun 10/13/2019 3:31 pm by software.current355386 | Last modified 10/14/2019 5:34 pm by Ray Borduin | 1483 views | 3 replies |
generated data assist pages , when run resultspage it shows records in database, insert seams to add new records but if you add a duplicate record it throes up an sql error subsequent insert reports the results page shows no records
the database has a unique key based on the SCREENID and SITEID combined see screenshot attached. I am trying to get a singe event for entry. for each SITE & Sreen Combination, if you could think of a different way to achieve same results,
Note there is already a MRT table retionship between sITE & SCREEN.
I'll need a URL to reproduce and FTP access to debug. What do you want to happen when a repeat is created? Should it allow repeats? Ignore them?
currently looking to utilise the MRT table linking screen and site .... by adding the relevant extra files to it and generate data assist pages to maintain the MRT TABLE . the delete and insert upyions disabled
can you think of any issues of going this mould providing the z`mrt relationship is maintained
Adding MRT shouldn't make the delete and insert options disabled. I'll need a URL to reproduce and FTP access to debug. What do you want to happen when a repeat is created? Should it allow repeats? Ignore them? I'm having trouble understanding the underlying issue. Is this a different issue than the first post?
