image not loading
Thread begun 10/12/2019 10:07 am by Jamie | Last modified 10/16/2019 9:16 am by Ray Borduin | 1458 views | 4 replies |
Jamie
image not loading
Hey Ray
another query re the history stuff I've been workign on. If I'm using image resizer the image loads fine when you come to the history.php page:
http://prntscr.com/pie1d2
however, when you select another line from the drop down, it stops the image from showing http://prntscr.com/pie25f
So guess its trying to access the cached image rather than the file name stored in the db but am unsure how, if possible, to get round this and still be able to use image resizer?
it also seems to be stopping the 'revert' function (go back to a previous version) if image resizer is included on the page
Cheers
Can I get a URL and FTP access with steps to reproduce? I'll have to take a look. You may just need an update to the framework files, or potentially an update to the plugin page itself.
Jamie
Sure thing and thanks. See PM
You reloaded the plugin: history_content.php, but the cached image library include only existed on the history.php page. I ended up doing quite a few things trying to figure out the issue, but what ended up fixing it was adding the image resizer library include onto the history_content.php page so that it would be available when the plugin reloaded.
Jamie
gotcha...thank you so much for taking a look and sorting
