Getting Array session into database
Thread begun 10/09/2019 8:21 pm by lr_leal239405 | Last modified 1/21/2020 9:00 am by Ray Borduin | 2354 views | 5 replies |
lr_leal239405
Trying to get Array session values into database with foreach with no success - only inserts last item of the array
Got a couple of days into trying to get this array to show in the 2nd page and then capture on database. All I get is the last line of the array. Attached are the files. I want to get the products into the confirm page and have it save to the database. I only get one line of products out of two.
This only applies to this line:
$ReplaceQuery->bindColumn("DetailItems", "s", "". implode(',',$value) ."", "WA_DEFAULT");
in the details table
You can see it by going to .com, Items in Stock - box, then, View Your Orders, then login with details below.
Make sure you add an x to the name of the file as such:
https://www..com/eCart/orders/order_historyx.php
(otherwise you'd be in the Live one).
On pressing Reorder, it goes to the form that is filled out and press submit which the Commit page handles. That's the page that won't all the rows into the db. (There's an array within an array by the way), so I'm pretty sure my logic is not very good.
You'll see all my commented out lines in my attempt to get it to work.- No Go.
There is a lot of custom code and commented out code on this page. I think we would have to do a screen sharing session with a premier support ticket to hash this out and find a solution.
If $value is set correctly as an array, then it might be as simple as using:
$ReplaceQuery->bindColumn("DetailItems", "s", $value, "WA_DEFAULT");
But I'd have to do debugging and work through everything up to that point to be confident. I don't think I can do all that in the context of a forum post.
lr_leal239405
ok. I thought so. I can call you later.
lr_leal239405
what is the latest I can call you tonight (or what works for you).
It's probably going to take about 15 after I show you.
Tomorrow morning would be better... but if you try tonight I may be available. Honestly the later the better like after the kids go to bed might work.
lr_leal239405
I'll call you later tonight, but just to simplify what I'm trying to do is get the value of the ForEach on the order_quoted_itemx.php to the confirm_order_quoted_itemx.php and have it go to the database. I only get the last value (of session I guess) from the while loop.
(the files without the x on the name are the live files).
I cleaned up a bunch of commented out lines (which were my attempts)
