Extension serial does not work anymore
Thread begun 9/17/2009 8:20 am by michel336265 | Last modified 9/18/2009 2:45 pm by Jason Byrnes | 3882 views | 4 replies |
michel336265
After a reinstallation off dreamweaver and the google pro extenstion the provided serial number is no longer accepted. I have tried it several times but no succes.
Please help
office172461
You might need to reset your activations.
See "Common causes of activation failure" in this document:
http://assets.webassist.com/technotes/activation.pdf
There was a glitch in our system that we have just fixed where the wrong serial number was being displayed for products purchased as part of a sweat.
The correct serial number should now be displayed on the Download center page.
michel336265
Still not able to activate
I have reset my activation, I have used the serial number which is in my order history and still I can not activate the extension.
What's wrong ?
I just tested the serial number listed in your download center using Pro Maps For Google 1.0.5 and was able to activate with out a problem .
make sure you are copying the serial number and pasting it into the window.
You can copy the entire number and paste it into the first box and it will automatically split into the remaining text boxes.
make sure you are not selecting any extra surrounding spaces when you copy the serial.
