Validation If not displaying for Validation Pass
Thread begun 10/02/2019 12:06 pm by Nathon Jones Web Design | Last modified 10/09/2019 10:48 am by Ray Borduin | 2083 views | 6 replies |
I've always used Validation Show If to display a message if validation fails.
I've tried setting up a page that displays a message if validation passes, however despite the validation passing, confirmed by the appended querystring on $WAFV_Redirect, the Validation Show If section is not displaying.
The server behaviour...
if (isset($_POST["smcresetBTN"]) || isset($_POST["smcresetBTN_x"])) {
$WAFV_Redirect = "reset.php?ve=1";
$_SESSION['WAVT_reset_570_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateEM(((isset($_POST["SMCuserUSER"]))?$_POST["SMCuserUSER"]:"") . "",true,1);
$WAFV_Errors .= WAValidateUnique("csdbmysqli",$csdbmysqli,$database_csdbmysqli,"SMCuser","SMCuserID","none,none,NULL","0","SMCuserUSER","',none,''","".(((isset($_POST["SMCuserUSER"]))?$_POST["SMCuserUSER"]:"")) ."",true,2);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"reset_570");
The form with the Validation Show If area...
<form action="" name="SMCresetpwFORM" method="post">
<div class="form-group">
<label for="SMCuserUSER" class="sr-only">E-mail address</label>
<input type="email" name="SMCuserUSER" id="SMCuserUSER" class="form-control" placeholder="Enter your e-mail address" value="<?php echo(ValidatedField("reset_570","SMCuserUSER")) ?>" required>
if (ValidatedField('reset_570','reset_570')) {
if ((strpos((",".ValidatedField("reset_570","reset_570").","), "," . "") >= 0)) {
if (!((strpos((",".ValidatedField("reset_570","reset_570").","), "," . "2" . ",") !== false || "2" == ""))) {
<small class="text-danger">Are you sure you've entered the correct e-mail address?</small>
<?php //WAFV_Conditional reset.php reset_570(:2)
</div>
<button class="btn btn-info btn-block" type="submit" name="smcresetBTN" id="smcresetBTN"><i class="fal fa-key"></i> Reset Password</button>
</form>
Hope you can help. Thank you.
NJ
OMG. I just can't cope with double negatives! :S
I am trying to validate if the entered e-mail address DOESN'T already feature in the users table. So, WAValidateUnique is the wrong validation to use because it's checking if the e-mail address DOES already feature in the users table. Right?
So can this even be handled with WA Server Validation?
Thank you.
NJ
Validate unique will make sure that the email address isn't repeated, so it will fail if the email address is already in the table. It sounds like that is what you want.
Actually no. I need to check if an email address doesn’t exist in the table.
Can you explain the use case? You want it to fail validation if the email address doesn't already exist? The way to do that is to create a recordset filtered by the submitted email address and then validate the number of rows in the recordset is greater than 0 using numeric validation. You just have to manually move the recordset above the validation code since it will be placed below by default.
I need to check if an e-mail exists in the system so that, if it does, we can send a password reminder.
If it doesn't, I need to display an error message.
Effectively we'd need to set up a simple search form here, to query the database. If TotalRows are 0 then it's safe to assume that the e-mail address doesn't exist and we can display an error message accordingly etc.
I think I was just stuck in using, completely, the WA Server Validation behaviour for this and then a double negative happened and my brain popped.
Much appreciated.
NJ
You should be able to add a recordset to the page filtered by the entered email address and then use validation to validate that the Total Rows returned is greater than zero.
