PHP if comparing recordset data and a session value - nothing working?
Thread begun 10/02/2019 11:05 am by Nathon Jones Web Design | Last modified 10/02/2019 8:10 pm by Ray Borduin | 1224 views | 2 replies |
What is wrong with this...
<?php if ($rsEDITFORM->getColumnVal["SMCformUSERID"] == $_SESSION['SMCinUSERID']) { ?>
Success.
<?php } ?>
I've also tried...
<?php if ($rsEDITFORM->getColumnVal("SMCformUSERID") == $_SESSION['SMCinUSERID']) { ?>
Success.
<?php } ?>
...this...
<?php if ($rsEDITFORM->getColumnVal("SMCformUSERID") == $_SESSION('SMCinUSERID')) { ?>
Success.
<?php } ?>
...and this...
<?php if ($rsEDITFORM->getColumnVa("SMCformUSERID") == $_SESSION("SMCinUSERID")) { ?>
Success.
<?php } ?>
...all without success. When I display both values on the page, they are the same value.
Please can someone help? I'm not seeing where the problem is, and I've also been using the "INSERT" option in DW to display these values and it always inserts this...
<?php echo($rsEDITFORM->getColumnVal("SMCformUSERID")); ?>
<?php echo $_SESSION['SMCinUSERID']; ?>
Thank you.
NJ
For no reason whatsoever, this is now working (example two from above)....
Success.
<?php } ?>
Coding gives me the absolute heebie-jeebies.
NJ
That is the one with the correct syntax... maybe you didn't upload it properly when you were quickly testing originally.
