DataAssist Insert password as encrypted (Hash)
Thread begun 10/02/2019 8:50 am by sandy170299 | Last modified 10/06/2019 3:08 pm by Ray Borduin | 1801 views | 5 replies |
sandy170299
Using DataAssist, how can I insert my password into the users table as encrypted data? I'm not seeing an option for this in the column bindings.
Thank you.
Are you using security assist or dataassist pages wizard? If you go to the "Field Settings" there is an encryption option.
sandy170299
I'm using DataAssist, and I'm not seeing an encryption option in the column bindings panel. Thanks.
DataAssist is a slew of wizards and Server Behaviors... What menu option are you using? In the DataAssist Pages wizard it is on the second tab with the "Configure Field Settings" label. This is what it looks like: Capture.PNG
sandy170299
I created the form and then used the MySQLi server behavior. Perhaps I should just use the DA wizard?
The DataAssist Wizard does a lot for you, so I'd suggest using it. If you want to do it from the server behaviors, then you select the encryption when you choose the bound value after you click the lightning bolt:Encryption.png
