access rules
Thread begun 9/30/2019 8:31 am by Jamie | Last modified 10/04/2019 9:09 pm by Ray Borduin | 1342 views | 4 replies |
Jamie
access rules
Hi Ray
Am using the pcms2_users table to store backend logins as well as front end member logins.
At the moment, if the user needs access to both front end and back end access, they have to have a separate email login for each and am wondering how I combine so that one login would give access to the relevant people
The backend is accessible only by Admin (UserGroupID=1), Publisher (UserGroupID=11) or Editor (UserGroupID=10)
The front end, at the moment, is only accessible to Members (UserGroupID=12) that are UserActive = 1
Am not sure how I would go about adjusting for this in the SA rules?
Have attached the helpergroupsrulesphp.php file as well as site def if you need it
Cheers
I don't really understand the question. Are you trying to update your members access rule to allow any user (admin or member)?
Jamie
yes it was the member access rule and have managed to figure it out.
on the same site the login page for the backend (attached) shows a failed login message (line 152) which works fine but I want to have an alternative message show if the user is a 'Members Only' tries to login but their UserGroupID = 12 and would show the message at line 155 instead
thanks
I think you could just use:
if (isset($_SESSION["UserGroupID"]) && $_SESSION["UserGroupID"] == 12)
Jamie
yup thats great Ray Many thanks
