session variables not being stored from login page to index page
Thread begun 9/28/2019 3:15 pm by sandy170299 | Last modified 10/02/2019 7:23 pm by Ray Borduin | 5499 views | 11 replies |
sandy170299
I applied the MySQLi Log In User behavior to the form on my login page. Fields are email and password. I'm storing user_id, user_email,and acct_number.
It's redirecting to my index page, but I can't get the session variables to show up.
My recordset is (index page):
$getUser = new WA_MySQLi_RS("getUser",$numeroseti,1);
$getUser->setQuery("SELECT users.* FROM users WHERE users.user_id = ?");
$getUser->bindParam("i", "".$_SESSION['user_id'] ."", "-1"); //WAQB_Param1
$getUser->execute();
I'm including relevant screen prints.
Thank you!
It could be a problem with the session_save_path in your php.ini file and sessions might just be not working. Is there anything else that might be taking it to the index page? Are you sure the session variables aren't being saved.
I'd probably debug by setting a session variable in php on one page and see if I can access it on another page. If the site doesn't store sessions properly then the code on the pages isn't the problem.
If sessions work, then I'd consider if it is somehow going to the index page without running the login code. Maybe the form action is set wrong?
sandy170299
My login name (MySQLi Login User) is user_id. I am also referencing this field in my log out page, using the MySQLi Log Out User server behavior (see screen print). It's not working. It's actually not logging me out. I tried a different browser this morning. Session variables DO work, as I'm using them again and again in the application for different processes.
This is my login form:
<form action="index.php" method="post" name="loginUser" onsubmit="MM_validateForm('email','','R','password','','R');return document.MM_returnValue">
<label for="email">Email</label>
<input name="email" type="text" id="email" value="leo@websailer.com" />
<label for="password">Password</label>
<input name="password" type="password" id="password" value="demo" />
<input name="submit" type="submit" value="Login" />
</form>
This is my login user script:
$Authenticate = new WA_MySQLi_Auth($numeroseti);
$Authenticate->Action = "authenticate";
$Authenticate->Trigger = (isset($_POST["submit"]) || isset($_POST["submit_x"]));
$Authenticate->Name = "user_id";
$Authenticate->Table = "users";
$Authenticate->addFilter("user_password_hash", "=", "s", "".((isset($_POST["password"]))?$_POST["password"]:"") ."");
$Authenticate->addFilter("user_email", "=", "s", "".((isset($_POST["email"]))?$_POST["email"]:"") ."");
$Authenticate->storeResult("user_id", "user_id");
$Authenticate->storeResult("acct_number", "acct_number");
$Authenticate->storeResult("user_email", "user_email");
$Authenticate->RememberMe = false;
$Authenticate->SaveLogin = false;
$Authenticate->AutoReturn = false;
$SuccessRedirect = "index.php";
$FailedRedirect = "";
if (function_exists("rel2abs")) $SuccessRedirect = $SuccessRedirect?rel2abs($SuccessRedirect,dirname(__FILE__)):"";
if (function_exists("rel2abs")) $FailedRedirect = $FailedRedirect?rel2abs($FailedRedirect,dirname(__FILE__)):"";
$Authenticate->SuccessRedirect = $SuccessRedirect;
$Authenticate->FailRedirect = $FailedRedirect;
$Authenticate->execute();
This is on index.php:
<?php session_start(); ?>
<?php require_once('Connections/numeroseti.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
<?php require_once('webassist/mysqli/authentication.php'); ?>
$getUser->setQuery("SELECT * FROM users WHERE user_id = ?");
$getUser->bindParam("i", "".(isset($_SESSION['user_id'])?$_SESSION['user_id']:"") ."", "-1"); //colname
I see the problem.... your login name is set here: $Authenticate->Name = "user_id";
But then you save a row result with the same session variable name here: $Authenticate->storeResult("user_id", "user_id");
That is causing a conflict. One or the other has to be updated so that they are unique.
sandy170299
So, I'm basically setting the session variable with the same name twice? Is that what you're saying? Where do you recommend I remove it from? The store values screen in the module?
Thank you.
Yes... I'd update the login name in the UI and then you will have to redo any page access rules and logout to match the new name.
sandy170299
Thank you. I can give that a try this evening.
sandy170299
Still not working. I created brand new login series of pages, and it doesn't redirect me, or give me any errors. It is supposed to redirect to index.php. This is in a completely different directory than what I was working on previously with this post.
Here is my login page:
<?php require_once('../Connections/numeroseti.php'); ?>
<?php require_once("../webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("../webassist/form_validations/wavt_validatedform_php.php"); ?>
<?php require_once('../webassist/mysqli/authentication.php'); ?>
<?php require_once( "../webassist/security_assist/helper_php.php" ); ?>
if ((isset($_POST["LogIn_submit"]) || isset($_POST["LogIn_submit_x"]))) {
$WAFV_Redirect = "".($_SERVER["REQUEST_URI"]) ."?invalid=true";
$_SESSION['WAVT_login_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ((isset($_POST["Log_In_group_user_name"])?$_POST["Log_In_group_user_name"]:"") . "",true,1);
$WAFV_Errors .= WAValidateEL((isset($_POST["Log_In_group_user_name"])?$_POST["Log_In_group_user_name"]:"") . "",6,100,true,2);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Log_In_group_2_user_password_hash"])?$_POST["Log_In_group_2_user_password_hash"]:"") . "",true,3);
$WAFV_Errors .= WAValidateEL((isset($_POST["Log_In_group_2_user_password_hash"])?$_POST["Log_In_group_2_user_password_hash"]:"") . "",6,500,true,4);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"login");
$Authenticate->Trigger = (isset($_POST["LogIn_submit"]) || isset($_POST["LogIn_submit_x"]));
$Authenticate->addFilter("user_name", "=", "s", "".((isset($_POST["Log_In_group_user_name"]))?$_POST["Log_In_group_user_name"]:"") ."");
$Authenticate->addFilter("user_password_hash", "=", "s", "".((isset($_POST["Log_In_group_2_user_password_hash"]))?$_POST["Log_In_group_2_user_password_hash"]:"") ."");
$Authenticate->storeResult("user_id", "SecurityAssist_user_id");
$Authenticate->RememberMe = (isset($_POST["Log_In_group_3_Remember_my_information"]));
$Authenticate->SaveLogin = (isset($_POST["Log_In_group_4_Log_me_in_automatically"]));
$Authenticate->AutoLogin = true;
$Authenticate->AutoReturn = true;
$FailedRedirect = "login.php?failedLogin=1";
<head>
<script src="../webassist/progress_bar/jquery-blockui-formprocessing.js" type="text/javascript"></script>
<link href="../webassist/forms/fd_basic_default.css" rel="stylesheet" type="text/css" />
<link rel="stylesheet" href="../webassist/jq_validation/Bloom.css">
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
</head>
<body>
<?php if(WA_Auth_RulePasses("Validated form")){ // Begin Show Region ?>
<p>Invalid username or password</p>
<?php } // End Show Region ?>
<?php if(WA_Auth_RulePasses("Log in success")){ // Begin Show Region ?>
<p>You have been logged in</p>
<?php if(WA_Auth_RulePasses("Failed log in")){ // Begin Show Region ?>
<?php if(WA_Auth_RulePasses("Emailed password")){ // Begin Show Region ?>
<p>Password information emailed, please check your inbox</p>
<?php if(WA_Auth_RulePasses("Successful update")){ // Begin Show Region ?>
<p>Registration completed successfully, please log in to access the site</p>
<div id="LogInContainer" class="WAATK">
<div id="LogIn_Basic_Default_ProgressWrapper">
<form class="Basic_Default" id="LogIn_Basic_Default" name="LogIn_Basic_Default" method="post" action="">
<fieldset class="Basic_Default" id="Log_In">
<legend class="groupHeader">Log In</legend>
<span class="fieldsetDescription"> Required * </span>
<div class="lineGroup">
<label for="Log_In_group_user_name" class="sublabel" > user_name:<span class="requiredIndicator">&nbsp;*</span></label>
<input id="Log_In_group_user_name" name="Log_In_group_user_name" type="password" value="" class="formPasswordfield_Medium" tabindex="1" title="Please enter a value." confirm="" required="true" />
if (ValidatedField('login','login')) {
if ((strpos((",".ValidatedField("login","login").","), "," . "1" . ",") !== false || "1" == "") || (strpos((",".ValidatedField("login","login").","), "," . "2" . ",") !== false || "2" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Log_In_group_user_name_ServerError">Please enter a value.</span>
<?php //WAFV_Conditional login.php login(1,2:)
</div>
<label for="Log_In_group_2_user_password_hash" class="sublabel" > user_password_hash:<span class="requiredIndicator">&nbsp;*</span></label>
<input id="Log_In_group_2_user_password_hash" name="Log_In_group_2_user_password_hash" type="password" value="" class="formPasswordfield_Medium" tabindex="2" title="Please enter a value." confirm="Log_In_group_user_name" required="true" />
if ((strpos((",".ValidatedField("login","login").","), "," . "3" . ",") !== false || "3" == "") || (strpos((",".ValidatedField("login","login").","), "," . "4" . ",") !== false || "4" == "")) {
if (!(false)) {
<span class="serverInvalidState" id="Log_In_group_2_user_password_hash_ServerError">Please enter a value.</span>
<?php //WAFV_Conditional login.php login(3,4:)
</div>
<label class="checklabel" for="Log_In_group_3_Remember_my_information">
<input type="checkbox" name="Log_In_group_3_Remember_my_information" id="Log_In_group_3_Remember_my_information" value="1" class="formCheckboxField_Standard" <?php if (!(strcmp((isset($_GET["invalid"])?ValidatedField("login","Log_In_group_3_Remember_my_information"):"".(isset($_COOKIE["RememberMe_user_name"])?"1":"") .""),"1"))) {echo "checked=\"checked\"";} ?> tabindex="3" title="Please enter a value" />
&nbsp;Remember my information</label>
</div>
<label class="checklabel" for="Log_In_group_4_Log_me_in_automatically">
<input type="checkbox" name="Log_In_group_4_Log_me_in_automatically" id="Log_In_group_4_Log_me_in_automatically" value="1" class="formCheckboxField_Standard" <?php if (!(strcmp((isset($_GET["invalid"])?ValidatedField("login","Log_In_group_4_Log_me_in_automatically"):"".(isset($_COOKIE["AutoLogin_user_name"])?"1":"") .""),"1"))) {echo "checked=\"checked\"";} ?> tabindex="4" title="Please enter a value" />
&nbsp;Log me in automatically</label>
</div>
<span class="buttonFieldGroup" >
<input class="formButton" name="LogIn_submit" type="submit" id="LogIn_submit" value="Log In" onclick="clearAllServerErrors('LogIn_Basic_Default')" tabindex="5" />
</span>
</fieldset>
</form>
</div>
<div id="LogIn_Basic_Default_ProgressMessageWrapper" class="blockUIOverlay" style="display:none;">
WADFP_SetProgressToForm('LogIn_Basic_Default', 'LogIn_Basic_Default_ProgressMessageWrapper', WADFP_Theme_Options['BigSpin:Slate']);
</script>
<div id="LogIn_Basic_Default_ProgressMessage" >
<p style="margin:10px; padding:5px;" ><img src="../webassist/progress_bar/images/slate-largespin.gif" alt="" title="" style="vertical-align:middle;" />&nbsp;&nbsp;Please wait</p>
</div>
</div>
</div>
<script src="../webassist/forms/wa_servervalidation.js" type="text/javascript"></script>
<script src="../webassist/jq_validation/jquery.h5validate.js"></script>
<script>
var LogIn_Basic_Default_Opts = {
focusout: true,
focusin: false,
change: false,
keyup: false,
popupClass: "Bloom",
pointedAt: "left",
fieldOffset: 10,
fieldMargin: 2,
position: "left",
direction: "left",
border: 1,
offset: 25,
closeText: "✖",
percentWidth: 100,
orientation: "bottom"
function LogIn_Basic_Default_Validate() {
$("#LogIn_Basic_Default").h5Validate(LogIn_Basic_Default_Opts);
$(document).ready(function () {
ConvertServerErrors(LogIn_Basic_Default_Opts);
</script>
</body>
</html>
sandy170299
I deleted everything and now tried just creating the login form using Webassist >> Forms >> Insert New Form.
Preset = Log in, Secure Login (I removed the question from the login form, but everything else is as is). This one is redirecting, but as soon as index.php has rules applied to it, it redirects me back to the login page. Also, it doesn't even appear to be interacting with a database table...???
My code is attached.
Thank you.
That is just a form... it doesn't have any of the login server behaviors applied.
To create a login form with login server behaviors you have to use SecurityAssist and not Form Builder.
