I have purchased your MySqli SB,,,, under webassist I select database nothing happens? Help???
Thread begun 9/27/2019 2:43 pm by stay99956137 | Last modified 1/11/2020 11:59 pm by Ray Borduin | 5547 views | 28 replies |
stay99956137
I have sent you a question already you are not responding
Did the secondary installer run after you installed? You usually have to open a page before the installation will complete. Then you have to restart Dreamweaver again after the secondary installer runs before the menu options work properly.
stay99956137
Hello Ray, Thamks for the responce...
No, a second installer did not run from what I remember?? Open what page? In Dreamweaver? I have opened a Php page and a HTML page? I have restarted Dreamweaver and the computer? Should I uninstall the MySqli SB extension and start all over???
Yes... try reinstalling the Extension. Then open Dreamweaver and open any page. It should pop up a secondary installer that runs with 3 steps. If that doesn't happen, then I'll have to do screen sharing with you to debug why the installer isn't working properly.
stay99956137
yes, I uninstalled , reinstalled with dreamweaver off,
it started popping up with error codes " While executing find Connection in WADYN_MYSQIL_CONN.htm, a JavaScript error occured.
Everything I try to do in dreamweaver, I try to open I try to close, The program is frozen, It did install the extension this time, I have to use the task manager to close Dreamweaver because it won't do anything...???
Try deleting your winfilecache.dat file in your user's configuration folder. If you post a US phone number or Skype contact information I can call you tomorrow to work through your issues and get the extension installed properly.
stay99956137
Trouble
Good Morning Ray,
I was able to get it to work somewhat,
I can't deal with this today, I will respond in a day or two,
Thanks for your time
Scott
Ok just post back here with your US phone number or Skype contact information in the private area and I'll call you to set up screen sharing and get any remaining issues resolved.
stay99956137
Help
I was able to get it to install by deleting the "winfilecache.dat file", However there are still some things not working right,
The insert, update and delete functions,
1.) I have followed your tutorial "Insert, update, delete records with MySQLi Server Behaviors" no matter what I do, nothing gets inserted, updated , or deleted, I have tried every possible combination , with different triggers and different dynamic data?? also according to your tutorial the code should be different
Please attach an actual copy of the page, not a version copied and pasted into word, so I can open it in Dreamweaver to take a look.
This page looks good to me. Is this the index.php page? I may need FTP access and a URL to reproduce the issue to fully debug it. Sometimes the problem is that your database has a required column that isn't being set in the server behavior and that causes the insert to fail.
