How do I upgrade older Data Assist pages from MySQL to MySQLi? I get the following error message on all my pages that use the MySQL database connection. Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the futur
Thread begun 9/26/2019 11:00 am by erinlima318673 | Last modified 9/26/2019 1:41 pm by Ray Borduin | 5881 views | 3 replies |
erinlima318673
I get the following error message on all my pages that use the MySQL database connection. Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /home/content/29/8748029/html/Connections/conn_inventory.php on line 9. We recently upgraded our PHP to 5.6 and will be upgrading to PHP 7 soon, and I want to fix all my pages so that they function properly when this migration occurs.
You can simply turn off that Depricated message and ignore it for now. You would only be forced to update your code when you go to a php7 server... this is just a warning.
To upgrade you just have to install DataBridge 2 and then open any Recordsets, Insert, Update, and Delete Server behaviors on the page and switch them to the MySQLi connection. Once you click OK with a MySQLi connection, then the code is updated to MySQLi.
erinlima318673
I did this, and it does update my DB connection to MySQLi, however every page that uses that connection now throws up the following errors causing my pages to not display at all:
Warning: mysql_select_db() expects parameter 2 to be resource, object given in /home/content/29/8748029/html/index.php on line 39
Warning: mysql_query() expects parameter 2 to be resource, object given in /home/content/29/8748029/html/index.php on line 41
those lines are part of the following function on the pages:
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
}mysql_select_db($database_conn_inventory, $conn_inventory);
$query_WADAusedbikes = "SELECT * FROM usedbikes WHERE new_or_used = 'Used' AND usedbikes.Status = 'In Inventory' ORDER BY ModelYear DESC, Importance DESC LIMIT 12";
$WADAusedbikes = mysql_query($query_WADAusedbikes, $conn_inventory) or die(mysql_error());
$row_WADAusedbikes = mysql_fetch_assoc($WADAusedbikes);
$totalRows_WADAusedbikes = mysql_num_rows($WADAusedbikes);
Line 39 refers to: }mysql_select_db($database_conn_inventory, $conn_inventory);
Line 41refers to: $WADAusedbikes = mysql_query($query_WADAusedbikes, $conn_inventory) or die(mysql_error());
You should be creating a new connection, not deleting and updating your old connection.
If you update the existing connection file, then the code on all of the other pages will be out of sync.
You should re-create your old MySQL connection so that your existing pages work.
Then create a new MySQLi connection and update Server Behaviors page by page to use the new connection and the code on the page will be updated to MySQLi to match the connection.
