Updating to Mysqli connections
Thread begun 9/21/2019 8:58 am by matthew316697 | Last modified 9/23/2019 12:56 pm by Ray Borduin | 733 views | 1 replies |
matthew316697
I am trying to update my old mysql_pconnect files to mysqli with Design Extender 2 after my web host updated PHP to 5.6 and my old PCMS installations failed to connect. However, after downgrading the PHP version to 5.4 and copying the correct details into the new Dynamic mysqli connection file I get a blank web page (the host doesn't echo errors). On my testing server I get the following:
Fatal error: Uncaught Error: Call to undefined function mysql_select_db() in C:\xampp\htdocs\GringoltsTestingServer\WA_Globals\WA_Globals.php:38 Stack trace: #0 C:\xampp\htdocs\GringoltsTestingServer\WA_CMS\WA_CMS.php(4): require_once() #1 C:\xampp\htdocs\GringoltsTestingServer\index.php(5): require_once('C:\\xampp\\htdocs...') #2 {main} thrown in C:\xampp\htdocs\GringoltsTestingServer\WA_Globals\WA_Globals.php on line 38.
Should the new connection file (attached) work straight away or are there other changes I need to make?
You can't simply update the connection. All of the pages would have to be manually updated to MySQLi as well. This would not be a simple process. We are working on an update to PowerCMS for MySQLi. In the meantime you should be able to run on php 5.6 without updating to MySQLi. I would work on that instead of trying to update to MySQLi, since that would be a very difficult process on your own without extensive php hand coding experience.
