The default value of an uploaded image is being removed when the form is submitted without making a change to the uploaded image.
Thread begun 9/16/2019 10:38 am by BillHobbs | Last modified 9/17/2019 9:22 am by Ray Borduin | 2276 views | 7 replies |
BillHobbs
When I use the upload file scripts the database value is being removed whenever the form is updated again without uploading another file. The default value from the database is not being applied.
Here is the code:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../pageimages/",
'FileName' => "[FileName]",
'DefaultFileName' => "".($WADApages_update->getColumnVal("pageTop")) ."",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End?>
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["Update"]) || isset($_POST["Update_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "pageTop", "0", "", "false", $WA_UploadResult1_Params);
This code looks correct. Can I get a URL to reproduce and FTP access to debug?
Maybe it is special characters in the image file name?
You might try:
'DefaultFileName' => "".($WADApages_update->getColumnVal("pageTop",false)) ."",
BillHobbs
I tried the code it didn't seem to work either.
You can see the file name above the file button. It shows up after the file is uploaded. I echo it after Top Image: Mobile Top Image: etc.
On line 116 you have:
$UpdateQuery->bindColumn("pageTop", "s", "".((isset($_POST["pageTop"]))?$_POST["pageTop"]:"") ."", "WA_BLANK");
it should be:
$UpdateQuery->bindColumn("pageTop", "s", "".($WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["serverFileName"]) ."", "WA_BLANK");
It looks like all of your file upload bindings are set wrong.
BillHobbs
This isn't working. None of the files were uploaded. And, the test.png is staying in the database.
In order to enable file upload your html <form> tag must have: enctype="multipart/form-data"
I've added that and the page seems to work properly now.
BillHobbs
That's weird. The form was set that way originally and was uploading. It could be that I've created those pages at least 5 or 6 times and I missed it on this round.
I did put the scripts through their paces and everything seems to be working right now.
I will note this, when I created the upload going through the file manipulation wizard I set the image options to Resize: None It set:
ResizeType = 0
ResizeWidth = 120
ResizeHeight= 120
ResizeFillColor = #FFFFFF
I changed those values to:
ResizeType = 0
ResizeWidth = 0
ResizeHeight= 0
ResizeFillColor =
Not sure if it was supposed to do that or not. I don't remember those values being filled in DataBridge V1.
I'll post the other bugs as I get to them again.
As always Thanks.
Once you have:
ResizeType = 0
The others are ignored... so that change wouldn't have an effect.
