modal database
Thread begun 9/13/2019 12:58 pm by software.current355386 | Last modified 9/16/2019 10:33 am by Ray Borduin | 688 views | 1 replies |
modal database
you are able to build modal db that assists you when using the query generator I heave some questions before I start using
1 do you generate on local system /testing server
2 can this be transferred to another machine/live site
3 are changes tov the tables reflected automatically in the modal
4 can this be printer
1) It is saved in your local site in the folder: webassist/datamodels/[connectionname].xml
2) You could send that file to another machine, you would have to do that manually
3) You cannot make changes to the table. This is just to define the joins and structure of an existing database to assist in creating queries, not for making actual edits.
4) There is no print option.
