Troubleshooting "Keep me logged in"?
Thread begun 9/13/2019 4:31 am by Justin@AdventDesign | Last modified 9/17/2019 3:31 pm by Ray Borduin | 1404 views | 4 replies |
Justin@AdventDesign
A client with a site I built several years ago has notified me the "keep me logged in" function no longer works. I have tested and confirmed the issue. I believe it worked when launched, but I guess I can't say for certain. I don't see any obvious glaring reasons why it wouldn't be working.
I'm unsure of how to troubleshoot something like this. Can you provide some direction on what to check and how?
It should save your login information into a cookie and use the cookie to log you in when this option is used. You could verify if the cookie is stored, and check if the login code is using the cookie information when it is available.
This is something I could help with in a premier ticket if you would like me to figure it out quickly.
Justin@AdventDesign
See PM
It works for me. I just tried and turned it on... now I'm automatically logged in when I return.
I'd have to debug this in a screen sharing session with someone experiencing the issue. If you post your phone number I can call you for screen sharing.
Justin@AdventDesign
You appear to be correct Ray. My initial test after the report was done incognito to avoid any previous cache or cookies, but since it is stored with a cookie, this would obviously not be correct. I will follow up with the client and see if we can track down their issue.
