submitted form email not being received
Thread begun 9/12/2019 7:15 am by Jamie | Last modified 9/12/2019 5:26 pm by Ray Borduin | 1967 views | 6 replies |
Jamie
Hey Ray
the attached contact-us.php form appears to submit successfully and redirect to the sent message but the email itself doesnt appear to be being sent.
By contrast, on the same install the 'send password' on the logins_results.php (also attached work absolutley fine. I cant see what, apart from the obvious differences in 'to' field etc, what the difference is and why the first one isnt 'workign'?
Cheers
It looks like it would work. Maybe something in the body content? Is there a url and FTP access I can use to debug it?
Jamie
sure see PM
I can't seem to get it working either. Does the forgot password link in the admin work? I tried creating simple email pages and they don't seem to work on this site. It could be a php.ini issue with the configured smtp server. Can you access SMTP logs on this server? Maybe ask your hosting provider.
I created a page: testemail.php
It is the simplest possible email test script, and it doesn't send either. I think it has to be a server configuration issue. Maybe show that page to your hosting provider's support team and ask them why it wouldn't send.
Sometimes the SMTP server can have issues and just has to be restarted.
Jamie
thats the odd thing, the 'forgotpassword' page for the admin area works fine as does a 'send password' on the logins_results page once logged into the cms.
Its just the contact page that isnt working.
Have attached the forgotpassword and the logins_results so you may be able to see what the difference is between them....
have also set up a login for you and hit 'send' which you should get shortly.....
I've been testing it further and it seems to have something to do with the email subject. I changed the subject and the emails are coming through. Again, you may be able to learn more if you contact your hosting provider and get the SMTP logs.
Jamie
many thanks for that Ray
Yes, they did come through fine after that... I tried "Contact Form" and that also works..whilst "Website Enquiry" or "Web Enquiry" do not work...
Again, many thanks
