Value not inserting
Thread begun 9/11/2019 12:58 pm by Steve | Last modified 9/12/2019 10:06 am by Ray Borduin | 826 views | 4 replies |
Steve
Value not inserting / Dropzone.js Drag and Drop uploader
I’m lost… Using a working drag and drop (dropzone.js) from one site to another and can not get 1 value (kind) to be inserted into a record.
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if (!empty($_FILES)) {
WA_DFP_UploadFiles("WA_UploadResult1", "file", "0", "", "true", $WA_UploadResult1_Params);
$InsertQuery = new WA_MySQLi_Query($tgdesign_i);
$InsertQuery->Action = "insert";
$InsertQuery->Table = "posts";
$InsertQuery->bindColumn("image", "s", "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."", "WA_DEFAULT");
$InsertQuery->bindColumn("kind", "i", "".$_SESSION['type'] ."", "WA_DEFAULT");
$InsertQuery->bindColumn("dateAdded", "t", "".((isset($_POST["hiddenDateTime"]))?$_POST["hiddenDateTime"]:"") ."", "WA_DEFAULT");
$InsertQuery->saveInSession("");
$InsertQuery->execute();
$InsertGoTo = "";
if (function_exists("rel2abs")) $InsertGoTo = $InsertGoTo?rel2abs($InsertGoTo,dirname(__FILE__)):"";
$InsertQuery->redirect($InsertGoTo);
Forcing a value of 63 into a new record insert and WORKS:
$InsertQuery->bindColumn("kind", "i", "63", "WA_DEFAULT”);
But anything dynamic FAILs such as:
Taking the value from a URLQuery into a var: <?php $type = $_GET["type"]; ?>
$InsertQuery->bindColumn("kind", "i", "".$type ."", "WA_DEFAULT");
Or from a Recordset:
$InsertQuery->bindColumn("kind", "i", "".($rsType->getColumnVal("typeId")) ."", "WA_DEFAULT”);
Or from a Session value:
$InsertQuery->bindColumn("kind", "i", "".$_SESSION['type'] ."", "WA_DEFAULT”);
I've checked the DB to confirm it's an Integer column which is it. Not sure what else to check.
Steve
Private Message
Steve
While my "other" version on a different site works well as a single page, this one required putting the File Upload and Insert Record code on a separate page.
So far look like this is the solution.
Most likely the $_GET variable and $_SESSION variable aren't being set in the right order or aren't being passed to the insert page properly when doing it on multiple pages. I'm sure I could debug it, but if you have a workaround that is better than me spending a bunch of time debugging code from another provider.
Steve
The values are present as I echo them in a latter place on the page. Also, I've done multiple means to introduce the value needed, $_GET, $_SESSION, $var and even a direct value put in the Insert routine.
I agree don't waste any debug time on this as I have already spent a considerable amount of time and now have a working solution. It's just that in the back of my mind I have the same coding logic working on a different site and now have this mystery why one site is different from the other.
Thank for offering Ray,
