Parse error: syntax error, unexpected 'if' (T_IF) in /Applications/MAMP/htdocs/Shop_2019/webassist/email/waue_quote_success_international_1_body.php on line 12
Thread begun 9/06/2019 10:40 am by Roxana | Last modified 9/07/2019 2:48 pm by Ray Borduin | 5373 views | 8 replies |
Roxana
After updating the Universal Email behavior to MySQLi and working out most of the error messages, this one I can't solve.
The same error is repeated multiple times on the page (line number shows in red), but only has one notification.
Supposedly it is a missing semicolon in the row before, but I don't think that applies here.
Two things... first you need to declare globals for any objects that are created on the main page and referenced in the email body, so you have to add this to the top of the page:
global $segufix$rscontent;
Then on the line referenced in the error you have:
if (!$segufix->IsEmpty());     {
It shouldn't have the semicolon... it should just be:
if (!$segufix->IsEmpty())     {
Roxana
I made the change. It is still showing the parse error. It also still shows the line numbers in red.
You still have the extra semi-colon..
if (!$segufix->IsEmpty()); {?>
should be:
if (!$segufix->IsEmpty()) {?>
Roxana
Sorry, I must have forgotten to save. I also removed a semicolon from line 43. It is still not working though
What is the current error?
Roxana
Parse error: syntax error, unexpected 'if' (T_IF) in /Applications/MAMP/htdocs/SEGUFIX-Shop_2019/webassist/email/waue_quote_success_international_1_body.php on line 15
update lines 14-16 to:
<?php  //WA eCart Show If Start
Roxana
Thank you, that helped, also with similar parse errors.
