Add menu
Thread begun 9/06/2019 9:10 am by massimo173451 | Last modified 9/07/2019 1:32 pm by Ray Borduin | 2497 views | 6 replies |
massimo173451
Add menu
Hi Ray,
I need to add a further menù and sub menù on top page in the PS 4.5, is this done by admin panel or manually modify the code if yes where I can find this code?? Thank you
Massimo
You can edit the webassist/plugins/main_menu/menu.php file directly to add menu items.
massimo173451
Ok Ray already done, but the new menù added (Appuntamenti)on tessyacconciature.it is not aligned with other menu why ??
What is the URL to the page so I can see the issue?
massimo173451
www.tessyacconciature.it...thanks Ray
You have mismatched <ul> and <li> tags causing the issue.
I think if you delete the </ul> tag on line 124 it should get you closer. I'd need FTP access to play with it to be sure, but it looks like that extra end tag is a big part of the problem.
massimo173451
Ok perfect. I will do it.
