PHP server doesn't have MySQL module
Thread begun 9/05/2019 7:49 am by vernon webb | Last modified 9/09/2019 5:50 pm by Ray Borduin | 2183 views | 7 replies |
vernon webb
All of a sudden I have been getting this error message (see attached) I'm not sure what's changed. As far as I know nothing on the server end...
vernon webb
FYI I downloaded the latest version as well but that didn't help
It is probably an issue with your site settings for your testing server. If you export your site and send me it then I can try to reproduce the issue and figure out the cause.
vernon webb
Its the same one I've sent you in the past. Nothing on my end has changed. Do you want me to send it to you again?
Check your testing server Web URL setting and make sure you have https:// not http:// at the front. You probably added an https:// redirect that is causing the old url to not work.
vernon webb
Still no good. Can you test yours and see if you have the same issue?
It worked for me once I updated the Web URL to include https://
vernon webb
Got it. I had to restart Dreamweaver after making the change. Thanks
