How do I debug php, if it will not show the errors.
Thread begun 8/30/2019 11:53 am by Roxana | Last modified 9/03/2019 1:45 pm by Ray Borduin | 1887 views | 4 replies |
Roxana
I have added to the page:
ini_set("display_errors",1);
But there is no hint at what could be wrong. This is after converting to MySQLi. I cleaned the code up as best as I could, but the page stays just blank.
There is no problem with the template code. Other pages are working.
Roxana
Online links in private section
Roxana
I was able to locate the problem and fix it.
Another problems are three repeating regions on the detail page.
rspricetable will return rows, but only if at least 10 rows can be returned (depending on the product). For less rows it returns nothing.
rsextraimages returns nothing.
rsversions returns all rows online, but not on my local server
I have tried deleting the behaviors and adding them again, but it made no difference. I also tried setting to the behavior to an arbitrary number for rows to be returned without any change.
Are you still having issues? I'm confused by the post. Please start new threads with new issues. Is this fixed like you mentioned in the first sentence, or were you referring to the earlier issue? If you still have this problem please post the url and I can take a look.
Differences in localhost and live are usually because of differences in the database.
Roxana
Yes, I was able to fix the original problem. I will post the new problem in a new post.
